Author Topic: Boost controler. Canadian source?  (Read 2083 times)
September 14, 2007, 03:42:19 am
haybayian
  • 155
« on: September 14, 2007, 03:42:19 am »
Hello,
I have read the other thread on the same topic but did not get all I need. I am looking for a straightforward  means of increasing my turbo's maximum boost from current 12 psi to 20 psi. My engine is the 1.9L AAZ, with an upgraded fuel injection pump, my turbo is a Garret. I would like to control the boost from my instrument panel, with gauge, knob,etc.
 What is the most practical system. Which Canadian source do you recommend?
Thanks.
Haybayian
Keep it simple if you can.
Reply #1September 14, 2007, 06:31:40 am
stewardc
« Reply #1 on: September 14, 2007, 06:31:40 am »
I got a simple 2-stage boost controller from the local speed shop. It has a switch for the dash. One position is adjusted to give relatively stock boost and when you need it, a flick of the switch will give me up to 30psi(adjustable also).
