Author Topic: Converting ECO/NA pump to Turbo with LDA  (Read 2154 times)
September 11, 2007, 01:22:25 pm
jase1979
  • 3
« on: September 11, 2007, 01:22:25 pm »
Hi,
I have sourced a pump top with LDA and wish to transplant it to my eco diesel pump. In the photo below I have highlighted two levers on the pump that I don't know what they do. Can somebody please help?
One of the levers is connected to a small spring inside the pump, what is this for? how would you connect this spring up while refitting the pump top?
Many thanks in advance.
Reply #1September 11, 2007, 03:15:20 pm
Black Smokin' Diesel
  • 656
« Reply #1 on: September 11, 2007, 03:15:20 pm »
Left one is the cold start advance lever, right one is... I dunno.
I'd get a genuine TD pump if I were you (or turn an NA pump into a TD pump) because the ECO pump has an 8mm plunger compared to 9mm for the na & td pumps.
Reply #2September 12, 2007, 02:41:20 am
jase1979
  • 3
« Reply #2 on: September 12, 2007, 02:41:20 am »
Both my pumps are from a 1.9td, I don't know the plunger size. The pump top is from a peugeot 306 td.
