Author Topic: 11mm Stretch head-bolts for an '81 1.6L diesel engine?  (Read 10698 times)
September 09, 2007, 09:02:48 pm
Michael
  • 1
« on: September 09, 2007, 09:02:48 pm »
I just had my head resurfaced (my wife said "it was about time!"), put a new 4 notch head gasket, like the old one, on it, and torqued it down with a set of stretch head bolts; thereby replacing the old non-stretch, 6 point hex bolts with the recommended "new-and-improved" star-point type.
As I was installing them - by the book, one of them would only torque to 55 lbs. So, fearing that I would twist the bolt apart, in my head, I decided that it was faulty, and went to the auto parts store to get another. Failing to get a single bolt replacement, and exasperated that he was unable to get me what I wanted, the parts guy told me that maybe a twist bolt was not recommended, and that I should use the non-twist type, since that was the OEM type.
My engine runs fine now, as it did before I had the head resurfaced, but the engine has the same problem that it did before: oil in the water.
I would like to know what I should do: put the original bolts back in the head, one by one, and torque it down; or, should I replace the stretch bolt with another one.
Thank you, in advance, for helping me to solve this mess.
Michael
Reply #1September 10, 2007, 05:37:16 am
saurkraut
  • 904
« Reply #1 on: September 10, 2007, 05:37:16 am »
The original 11mm head bolts do not thread very far into the block.
The one that won't torque is stripping the block.
Get a set of head studs from either Raceware, or ARP.  The studs go allot deeper into the block, and will reach the good threads in the base of the hole that is stripped.
I had the same thing happen on my 1.5.  Got the Raceware studs and everything is OK.
Here's the Raceware link: http://www.raceware-fasteners.com/
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2February 08, 2008, 02:04:05 pm
Baselyne
« Reply #2 on: February 08, 2008, 02:04:05 pm »
How Much were those raceware studs?
I heard people telling outragous prices of 200$ for 10 bolts
is this true?
Reply #3February 08, 2008, 03:04:19 pm
MaxHedrm
  • 114
    • blog
« Reply #3 on: February 08, 2008, 03:04:19 pm »
Quote from: "saurkraut"
Wow ... that has got to be the worlds 3rd most useless website. Seriously bad marketing. There is almost NO information there.  :roll:
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #4February 09, 2008, 05:00:02 am
saurkraut
  • 904
« Reply #4 on: February 09, 2008, 05:00:02 am »
Yep, the site is really basic, but it gets the pont accross.  Studs are stronger than torque to yeild fasteners.  Just shows that they don't spend money on on a marketing dude and an IS dude.  (Nothing against marketing, I have a few years of marketing in my background)  Their catalog is allot better.
I think the head studs are around $125 USD plus shipping.
I have had them in my 1.6TD, running 25PSI boost for over 4 years with no problems.
I would imagine the ARP studs would perform similarly, but I don't know their price
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5February 10, 2008, 02:18:49 pm
Baselyne
Prices for 1.5L 11mm headstuds!
« Reply #5 on: February 10, 2008, 02:18:49 pm »
11mm raceware's are $189.05USD plus shipping
Reply #6February 10, 2008, 11:45:42 pm
Turbinepowered
  • 1206
« Reply #6 on: February 10, 2008, 11:45:42 pm »
Quote from: "Baselyne"
is this true?
Studs, not bolts. Reusability is the key difference, and if the studs' better holding characteristics save you from a block replacement (Stripped threads or cracking) or frequent head-gasket jobs (due to stock bolts' poor holding power, gasket sealing issues), is it worth the extra up-front cost?
Reply #7February 11, 2008, 10:56:56 am
Baselyne
headbolts.com
« Reply #7 on: February 11, 2008, 10:56:56 am »
why does this site list the 80 diesel 1.5L to be 12MM bolts?
http://headbolts.com/Volkswagon-Audi-diesel-fasteners.html
I thought 1.6 and 1.5 bolts were different
Im told 11 x 98mm for 1.5L
and 11 x 115mm for 1.6L
Reply #8February 11, 2008, 11:28:37 am
saurkraut
  • 904
« Reply #8 on: February 11, 2008, 11:28:37 am »
THE WEB SITE IS WRONG.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
