Author Topic: Arghhh still smoking? need help!  (Read 2322 times)
September 07, 2007, 12:01:38 pm
coolerow
  • 10
« on: September 07, 2007, 12:01:38 pm »
Alright guys needed some help with my retarded 1.5D
I've been tinkering with this engine to stop it from smoking(white-ish) constantly with no success. So far I've REBUILT the engine, new guides/seals in cylinder head,  injector nozzles, injector heat shields, fuel lines, fuel filter, and timed the pump to the best of my ability. I even bought another used(but working good) pump. After all that it is still smoking like it did before. White smoke constantly that burns the eyes.  :shock:
Anyone have any tips? If it helps my engine is somewhat louder than other diesels i've seen. Is it the valve adjustment, i hope not cause I would need to buy the tools(more $$$).
Reply #1September 07, 2007, 01:00:47 pm
Op-Ivy
  • 513
« Reply #1 on: September 07, 2007, 01:00:47 pm »
White smoke is usually a sign of unburnt diesel. What do you have your timing set at?
Matt
Reply #2September 07, 2007, 01:45:30 pm
coolerow
  • 10
« Reply #2 on: September 07, 2007, 01:45:30 pm »
.83mm like the book says?
Reply #3September 08, 2007, 06:36:51 pm
vegfuel
  • 125
« Reply #3 on: September 08, 2007, 06:36:51 pm »
Have you tried looking at your coolant level? You may be burning coolant. What does the smoke smell like?
1986 Golf WVO converted.
Reply #4September 08, 2007, 08:42:30 pm
2mAn
« Reply #4 on: September 08, 2007, 08:42:30 pm »
yea it sounds like the timing is off. mine smoked lil a damn forest fire til i timed it right.
