Author Topic: alternator upgrade  (Read 3012 times)
February 16, 2005, 09:19:02 pm
  • 2931
alternator upgrade
« on: February 16, 2005, 09:19:02 pm »
There was a guy over on the vortex that wanted to buy a non-AC alternator bracket, for a Rabbit, from me.
 He has power steering and I didn't think mine would work for him so I went looking for Jake's old post on his alternator upgrade.
 Something everyone here should take a look at.
 http://www.hostboard.com/cgi-bin/ultimatebb.cgi/ubb/get_topic/f/4037/t/592/p/1
 Jake the one picture is of a 55 amp alternator. Is the one you finally ended up with a 55 amp?
Reply #1February 16, 2005, 10:35:13 pm
srivett
  • 318
alternator upgrade
« Reply #1 on: February 16, 2005, 10:35:13 pm »
If I ever get enough money together I'll be switching to the serpentine belt system.  The kit I saw was just a pile of 1.9 parts including an AC IP/alternator bracket.  Was there also a non-AC bracket available?
I do not like the sound the v-belt makes when the glow plugs run for 3 minutes after startup.
Thanks, Steve
1992 1.6D Golf - 412K km
Reply #2February 18, 2005, 08:52:36 pm
fspGTD
  • 1529
alternator upgrade
« Reply #2 on: February 18, 2005, 08:52:36 pm »
If you take a look at the alternator "dyno" plot, you can see that I think it gets up to around 55AMPs at the correct temperature and sufficient RPM.  I think denso may have officially "rated" it at a bit lower than that, though ((45AMP?).  However, other firms who re-sell that alternator under their own label do advertise it as a 55AMP units.
Jake Russell
Reply #3September 06, 2005, 10:11:45 am
rackley
  • 96
alternator upgrade
« Reply #3 on: September 06, 2005, 10:11:45 am »
Wow, lots of good info, but going with a custom bracket for a non-stock alternator is really just too much work for what I want to do.  Does anyone know if it's possible to modify the existing alternator to self-excite or if there's a drop-in replacement that does so?  BTW, I'm talking about the 90A A/C alternator here.  Or maybe a good alternator shop that knows VWs that could advise on this issue?
Thanks,
Ray
www.vocontrol.com
VO Control - Programmable VegOil and WVO Controllers
Reply #4September 06, 2005, 10:12:56 am
rackley
  • 96
alternator upgrade
« Reply #4 on: September 06, 2005, 10:12:56 am »
Lol, whoops, replied in the wrong thread :-)
www.vocontrol.com
