Author Topic: Piston wear pattern  (Read 6177 times)
August 21, 2007, 03:01:34 pm
rallydiesel
  • 1880
Piston wear pattern
« on: August 21, 2007, 03:01:34 pm »
I was measuring the pistons I am replacing and noticed that they are slightly narrower from side to side. I thought pistons would tend to wear more fore/aft due to the crankshaft motion. Do I have some thing going on that I should take care of before I put my engine back together?
By the way, they are 77.48 pistons (third oversize) but are worn down at the top 77.00 side to side and about 77.10 fore/aft. The bottoms are about 77.40 all the way around. They seem to be in pretty good condition aside from the wear if anybody is interested in them.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1August 23, 2007, 02:53:49 pm
rallydiesel
  • 1880
Piston wear pattern
« Reply #1 on: August 23, 2007, 02:53:49 pm »
Anybody?
Reply #2August 24, 2007, 06:34:09 am
saurkraut
  • 904
Piston wear pattern
« Reply #2 on: August 24, 2007, 06:34:09 am »
You are observing the normal shape of a piston.  the sides are usually narrower than the skirts.  Typically, they are also smaller diameter at the top than the bottom.
http://www.tpub.com/machines/12g.htm
http://courses.washington.edu/engr100/All_Sections/Engine/UofWindsorManual/Piston%20Design.htm
http://www.hobbytech.com/PistonCam.htm
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
