TDI Engine -General Info
Fit 2001 ALH tdi engine in MK3 Jetta?
Topic: Fit 2001 ALH tdi engine in MK3 Jetta? (Read 7175 times)
August 21, 2007, 04:33:29 am
4BTA4ME
August 21, 2007, 04:33:29 am »
I contacted Jeff at Rocket Chip about immobilizer defeat in my swap project and he said;
"That Mk4 engine won't easily fit in M3 body".
Can anyone shed some light on this?
August 21, 2007, 06:22:01 am
Slave2School
August 21, 2007, 06:22:01 am »
Rear engine mount.
Waiting for a bigger better diesel to come along.
2002 ford focme wagon
August 21, 2007, 08:40:11 am
4BTA4ME
alh in mk3
August 21, 2007, 08:40:11 am »
Is it an interference with turbo? My plan is to use the MK3 engine mounts bolted to the ALH.
August 21, 2007, 08:51:42 am
Slave2School
August 21, 2007, 08:51:42 am »
Yes, check this out.
http://forums.tdiclub.com/showthread.php?t=170078&highlight=mount
August 21, 2007, 09:49:06 am
4BTA4ME
August 21, 2007, 09:49:06 am »
Thanks. That looks easy enough to duplicate with my mill machine and metal burrs.
August 21, 2007, 10:26:35 am
vwmike
Authorized Vendor
August 21, 2007, 10:26:35 am »
You'll probably have to do some work on the front mount bracket as well. I had to grind down the back of my mount to clear the crank sensor and then I added a brace with a gusset over to the starter bolt.
August 21, 2007, 12:33:46 pm
4BTA4ME
August 21, 2007, 12:33:46 pm »
Good. I can handle that one with the plasma cutter and welder.
August 21, 2007, 02:00:40 pm
MikkiJayne
August 21, 2007, 02:00:40 pm »
Where's G60ING to post a link? :wink:
He did an ALH in a Corrado which is pretty much the same swap. There are some pics in here that show how the mount needs modifying:
http://forums.vwvortex.com/zerothread?id=2303271
Mikki x
