General Information
Troubleshooting
Turbo not as audible??
Topic: Turbo not as audible?? (Read 4970 times)
August 20, 2007, 10:12:27 pm
dieseldubber
August 20, 2007, 10:12:27 pm »
Hey guys, I can't hear my turbo whine like I used to. There is no noticeable loss of power though. Any explanations? I did lose my tailpipe a while back so the car is a bit louder altogether but I have been really trying to hear the turbo and its not noticeable like it used to be.
'85 1.6TD JettaGL
August 20, 2007, 10:19:41 pm
August 20, 2007, 10:19:41 pm »
Were any other changes done to the car? What type of car is this?
August 22, 2007, 06:27:25 am
dieseldubber
August 22, 2007, 06:27:25 am »
its an 85 jetta td
'85 1.6TD JettaGL
August 22, 2007, 10:23:41 am
August 22, 2007, 10:23:41 am »
Dirty air filter?
August 22, 2007, 09:10:28 pm
dieseldubber
August 22, 2007, 09:10:28 pm »
ya that could be i'll check
'85 1.6TD JettaGL
August 22, 2007, 09:39:20 pm
August 22, 2007, 09:39:20 pm »
low oil can do weird things to the turbo too... and bad contaminated oil also.
remember that the shaft spins on a 'cushion' of oil. a ball bearing turbo would be pretty pimp, but are expensive. best i can suggest is try changing your oil and see if you notice a difference. if you've changed recently, then take off the intake pipe and just check for play. pretty easy to do.
i personally notice a big difference after an oil change. my turbo spools beautifully. i notice when i have low oil when the turbo doesnt spool until later in the rpm range. if that makes sense
oh and don't forget to let the car warm up a bit before stompin to get your turbo blowin. that turbo needs to heat up first, and can take a few minutes of driving. if driven hard when cold, you may screw up the turbo... just fair warning
August 23, 2007, 09:20:13 pm
dieseldubber
August 23, 2007, 09:20:13 pm »
thanks much that is some very decent advice there. the oil has been changed not too long ago but yeah I will consider all of what you said. I do think part of it is my loud exhaust drowning it out but thats not all. Thanks again.
'85 1.6TD JettaGL
August 24, 2007, 10:07:30 am
August 24, 2007, 10:07:30 am »
did you install a larger downpipe? that should make the turbo more audible if anything... (with a nice free-er flowing exhaust)
August 24, 2007, 08:10:16 pm
dieseldubber
August 24, 2007, 08:10:16 pm »
nope but, thats next. Thanks for the advice guys but I think everything is ok now. I do hear it and no loss of power so I am not worried.
'85 1.6TD JettaGL
General Information
Troubleshooting
