General Information
Troubleshooting
Plugged a/c condensate drain - '92 Jetta
Topic: Plugged a/c condensate drain - '92 Jetta (Read 5011 times)
August 19, 2007, 05:55:50 am
larry104
August 19, 2007, 05:55:50 am »
Where is the a/c condensate drain on a '92 Jetta and how do you clean it out? I didn't see any water dripping under the car when the a/c was on and the driver's side carpet was wet.
August 19, 2007, 06:49:58 am
August 19, 2007, 06:49:58 am »
I think it is right at the bottom of the HVAC box in the car. It travels out the firewall just behind the engine. Mine was dealer installed AC, not factory so it might be a bit differant
August 19, 2007, 06:16:51 pm
larry104
August 19, 2007, 06:16:51 pm »
Fixed it. Thanks.
August 19, 2007, 06:27:49 pm
August 19, 2007, 06:27:49 pm »
was I right?
August 20, 2007, 05:27:58 am
Kneale Brownson
August 20, 2007, 05:27:58 am »
Quote from: "larry104"
Fixed it. Thanks.
What was the fix?
August 20, 2007, 05:28:27 am
larry104
August 20, 2007, 05:28:27 am »
Quote from: "burn_your_money"
was I right?
Yes, the drain exits on the firewall. I disconnected it from the heater box inside the car and ran a stiff piece of wire up there, then reassembled it. It drains now. Thank you.
August 20, 2007, 08:11:56 am
August 20, 2007, 08:11:56 am »
Perfect. I just wanted to know if it was right spot for future reference.
Glad you got it straightened out
General Information
Troubleshooting
