Finally started this job
1994 2.0 Golf
(less motor)
Moving into the 94 golf:
-1.6td and trans
-T3 off of a saab (oil and water cooled, not sure how the hell I'm going to do the water part)
-ebay 8v exhaust manifold
-G60 intake manifold
-shifter and pedal cluster (golf is auto!)
-Mk2 subframe, A-arms , knuckles, brakes etc - moving the whole mess over so i don't have to mess with making motor / trans mounts fit, and most importantly the axles
-intercooler: don't have one yet, but hopefully soon
Feel free to punch holes / point out flaws in my plans, I don't have any experience with swaps and even less time to get this done!
Done so far:
-Mk2 shifter box does not bolt up to mk3, It is too wide, so I trimmed the sides off and welded on some flanges to match the mk3 auto box
-Exhaust manifold from Ebay is , i think, designed for x-flow, had to grind a little to make it fit with the g60 manifold
--Turbo T3 from Saab 9000
-Didn't bother with the water cooling of the turbo, after some looking around, looks like a lot of kids are just pluggin' the water holes. As long as i don't beat on it before it gets warm and let it cool down when i park, should be ok.
-The turbo exhaust outlet ( downpipe flange ) has a tapered stub on it which makes it tougher to fabricate a d.p. flange. To avoid that, I got the saab downpipe and cut it after the first elbow. It's a little smaller dia than the 2 1/2" I'm going to weld to it, but its a nice sweep that goes further than 90 deg, so it should get me away from the shifter linkage.
-Clutch cable: mk3 pedal doesn't hook up to mk2 clutch cable
Got a mk3 clutch cable but had to drill out the mk2 clip that holds the end of the cable on the trans. to 1/4" dia
-Throttle cable: 2.0 gas throttle cable is too short and has wrong end on it, won't hook up to injection pump
mk3 pedal doesn't hook up to mk2 throttle cable. I ordered a throttle cable for a Canadian mk3 1.9TD, but they sent me a self adjusting clutch cable instead. I think because I'm in the states, their system farted and when I requested a part for a Canadian car...
-Radiator: mk3 radiator not as wide, but taller than mk2 diesel rad
Inlet and outlet are not in exactly the same locations, fan plug is different
I'm going with the mk3 radiator, even tho its been patched with some kind of epoxy in a few places, I can't spend any more money before I see this thing start up at least.
