Author Topic: FS: 91TD jetta coupe unfinished project  (Read 3576 times)
August 13, 2007, 07:24:34 am
Mr pink
  • 3
« on: August 13, 2007, 07:24:34 am »
This is a 91 jetta coupe diesel project I started but never finished. Car started life as a standard diesel. Body is red and in good condition there is surface rust around the front window, no rust other than that. The only mods to the car is the round headlight rad support. I aslo have a set of grey recaros that will go with the car.
 The motor is 95% complete. Most of the parts are there  One part missing is the bracket that holds the injection pump.
Motor is:
95 canadian 1.9td
rebuilt head new headgasket and bolt
1.6td injection pump
new timing belt (not installed)
new valve cover gasket
210mm flywheel new clutch and PP
new 1.6 turbo
all the oil feed and drain lines ( will need to be modded to fit with the 1.6 turbo)
1.6td fuel lines.
alt, a/c comp, and p/s will be included
I'm an willing to split the car and motor up. I would like to get $2500 for the car and the motor. If you have any questions please email me at [email protected]
Thanks Randy
