Author Topic: Correct Idle Speed  (Read 2357 times)
August 12, 2007, 06:52:46 am
Fingaluna
  • 13
Correct Idle Speed
« on: August 12, 2007, 06:52:46 am »
Hi Folks,
What should the idle be at for a stock 1994 Jetta TD?
Thanks,
Matt
1994 Jetta TD Biodiesel
1998 Chevy Astro - 4 kids won't fit in a Jetta!
1981 Yamaha Virago 750
1965 Vespa 125
Reply #1August 12, 2007, 09:33:52 am
Zulfiqar
  • 254
Correct Idle Speed
« Reply #1 on: August 12, 2007, 09:33:52 am »
IIRC its 950 rpm according to the manual, Once your pump is timed correct, you can feel the correct idle speed, when the residual and idling screw settings are spot on it will start by a bump of the starter.
In my Golf's case if I mess around with increasing the idling speed or the residual it becomes a pig to start
Diesel IS the future
Reply #2August 12, 2007, 09:35:33 am
Zulfiqar
  • 254
Correct Idle Speed
« Reply #2 on: August 12, 2007, 09:35:33 am »
Reply #3August 13, 2007, 08:49:18 pm
Fingaluna
  • 13
Correct Idle Speed
« Reply #3 on: August 13, 2007, 08:49:18 pm »
Great, thanks. Mine is a bit higher, around 1000. I know that my injectors are in rough shape though, so that might explain it...
Cheers,
Matt
1965 Vespa 125
