Author Topic: Gasser Intake!!!!  (Read 4086 times)
December 31, 2007, 03:46:02 pm
dillenger1
  • 777
Gasser Intake!!!!
« on: December 31, 2007, 03:46:02 pm »
Ok i just got my g60 intake today,anf im wondering if theres a use for the throttle body?I love the mechanics of the thing,id hate to throw it away(dont worry it will never happen).I was thinking like some sort of a return or something
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1December 31, 2007, 06:49:43 pm
blkboostedtruck
  • 1535
Gasser Intake!!!!
« Reply #1 on: December 31, 2007, 06:49:43 pm »
you can use it to divert from supercharger air and at full throttle to turbo air! you need that for your twin induction that your building!
i thought you knew? L.O.L.  :lol:
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2December 31, 2007, 10:06:25 pm
flapjack
  • 283
Gasser Intake!!!!
« Reply #2 on: December 31, 2007, 10:06:25 pm »
if you've got the boost return section you can use it as a square to round transition.  I cut off the little tube with the butterfly, welded the opening shut and I think the inlet is 2 1/2" OD. Heres the pictures posted by RabbitGTDguy
from his post http://vwdiesel.net/phpBB/viewtopic.php?t=1956
signature
Reply #3December 31, 2007, 10:08:42 pm
lyeinyoureye
  • 96
Gasser Intake!!!!
« Reply #3 on: December 31, 2007, 10:08:42 pm »
A kill switch for runaway?
Reply #4January 01, 2008, 03:03:00 am
OM617
Gasser Intake!!!!
« Reply #4 on: January 01, 2008, 03:03:00 am »
An engine brake. Close the throttle during deceleration to generate intake vacuum and an engine braking effect.
Reply #5January 01, 2008, 03:48:18 am
dillenger1
  • 777
Gasser Intake!!!!
« Reply #5 on: January 01, 2008, 03:48:18 am »
Is that picture of the throttle body ,before it got closed up?It doesnt seem like you would be able to run a pipe off of that?
Reply #6January 01, 2008, 07:00:13 am
flapjack
  • 283
Gasser Intake!!!!
« Reply #6 on: January 01, 2008, 07:00:13 am »
it isn't the throttle body, its the boost return section which bolts to the TB.
signature
Reply #7January 01, 2008, 08:07:02 am
RabbitGTDguy
  • 1274
Gasser Intake!!!!
« Reply #7 on: January 01, 2008, 08:07:02 am »
Quote from: "flapjack"
Yes, that is right. It is the boost return section of the G60 throttle body. I don't believe I put a pick of it up "unmodified" but you do need to gut the boot return valve out of it, do a little fine cutting (I with my dremel) and then weld the section close that you don't want to use. Its worked perfect for me with NO problems. I think the hardest part was finding someone willing to get rid of the boost return section of the throttle body without trying to sell me the TB at the same time.
Joe
1972 VW Westfalia
Reply #8January 01, 2008, 08:16:22 am
flapjack
  • 283
Gasser Intake!!!!
« Reply #8 on: January 01, 2008, 08:16:22 am »
dremel? fine cutting? :) i used a hacksaw :)   cut off the whole deal and welded an aluminum plug in place.
What are you using for an exhaust manifold?
signature
Reply #9January 01, 2008, 10:37:58 am
dillenger1
  • 777
Gasser Intake!!!!
« Reply #9 on: January 01, 2008, 10:37:58 am »
The boost return is the down turned piece?Or is that a entire different piece that i dont have.[/img]
Reply #10January 01, 2008, 05:03:50 pm
RabbitGTDguy
  • 1274
Gasser Intake!!!!
« Reply #10 on: January 01, 2008, 05:03:50 pm »
Great...i had more fun with the dremel and ended up making it nice and flush just how I wanted it. By fine cutting, I didn't mean any surgeon stuff...  I just prefer the dremel :)
my manifold is a 8v backset t3 manifold. Its in the thread if you want to find it...
Quote from: "dillenger1"
The boost return is the down turned piece? Or is that a entire different piece that i dont have.
Well...kinda can't see what you have (did you try to post a pic?) but the pictures above REALLY kinda show you the piece that you need... if you don't have the G60 throttle body/boost return section as part of the intake manifold....then no...you probably don't have the piece. Again, its part of the throttle body from the G60....just bolts to the throttle body...
I'm actually good up something even better and new this winter for the intake manifold on my mTDI...fun fun.
Joe
1972 VW Westfalia
Reply #11January 02, 2008, 05:01:51 am
flapjack
  • 283
Gasser Intake!!!!
« Reply #11 on: January 02, 2008, 05:01:51 am »
Quote from: "RabbitGTDguy"
I know your thread. It's helped me a lot.  Great thread. I got the same g60 intake and gas t3 exhaust manifold because of you. I was asking the original poster
signature
Reply #12January 04, 2008, 01:59:32 pm
dillenger1
  • 777
Gasser Intake!!!!
« Reply #12 on: January 04, 2008, 01:59:32 pm »
