Author Topic: mercedes injectors vs GTD injector nozels?  (Read 3532 times)
July 23, 2007, 07:48:15 pm
jaw174
  • 18
« on: July 23, 2007, 07:48:15 pm »
which is betteR?
Reply #1July 23, 2007, 07:57:58 pm
subsonic
  • 1836
« Reply #1 on: July 23, 2007, 07:57:58 pm »
Reply #2July 23, 2007, 08:29:24 pm
« Reply #2 on: July 23, 2007, 08:29:24 pm »
I'm in the process of building a set of both... me and my gTech will take them for a spin and let you know.   Breaking pressure will be set exactly the same, as will pump timing etc.
My money's on the Mercedes nozzles, based on what I've read, but I already bought the GTDs so will test 'em both.
Reply #3July 23, 2007, 09:04:27 pm
Black Smokin' Diesel
  • 656
« Reply #3 on: July 23, 2007, 09:04:27 pm »
At one time not so long ago I had a set of injectors with GTD nozzles and mercedes injectors. I noticed that the needle was quite bigger on the merc nozzles.
I installed the merc injectors when I replaced the head (along with a 1.9td metal HG). Right now power is a bit under standard TD power only because I cut the fuel a fair bit (I wanted to wait for the required re-torquing of the headbolts after 1000 miles). Now that it's done I'll be upping fuel shortly. I hope to see nice gains from those injectors.
Reply #4July 23, 2007, 10:26:00 pm
Jetman
  • 11
    • http://www.netikka.net/vepiku
« Reply #4 on: July 23, 2007, 10:26:00 pm »
aaz metal hg don`t need re-torquing..
Autodata says, stage 1: 40nm stage 2:60nm stage 3: 90deg. stage 4: 90deg.
Reply #5July 23, 2007, 11:03:20 pm
  • 656
« Reply #5 on: July 23, 2007, 11:03:20 pm »
Quote from: "Jetman"
I don't think it has anything to do with the HG I used. The bolts are stretch bolts and they stretch a bit at first. When I re-torqued them they were definitely easier to tighten than when I torqued them the first time around before running the engine.
The MK2 bentley has the same initial torquing procedure you described but adds 1/4 turn after first warmup at idle and another 1/4 turn after 1000miles.
