Author Topic: Results of Ultra Low Sulfur Diesel  (Read 14001 times)
July 16, 2007, 07:43:17 pm
dlorimer
  • 31
« on: July 16, 2007, 07:43:17 pm »
Ok, the time has come for a thread detailing the results and fixes regarding Ultra Low Sulfur Diesel (ULSD).
The law changed here in January of 2007.  I have been running it since then without additives (my stupidity).  I have recently discovered a major leak at the top of my water separator, a leak on my fuel filter, and a leak on my Injector Pump.  Also, I have detected a leak in the cylinder o-rings.  Besides leaks, my mpg is about 3 mpg lower than before.
Anyone else with similar experiences?  Also, what additives are best for ULSD.  I am definitely needing to start using them before this stuff completely destroys my car!
Reply #1July 16, 2007, 08:16:47 pm
hillfolk'r
  • 1532
« Reply #1 on: July 16, 2007, 08:16:47 pm »
i was talkin with the place where i used to work in ohio,and they said they are gettin power stroke injector issues+some increase on pump problems
this new ulsd sounds like shades of the early 90's all over again with pump /injector issues :evil: (thumbdown)
ive heard all kinds of stuff so far
"add 2 stroke oil"
"add fuel additive,just make it 2x the recommended dose",,etc etc..
Throttle cables ftw
Reply #2July 17, 2007, 05:39:37 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #2 on: July 17, 2007, 05:39:37 am »
ULSD has been out in australia for a couple of years now.
vw make a point here of saying to use it in the new tdi's, but i found that my old 1.5n/a got lower milage, more smokey using it.
i think for the older idi's there are a couple of things you could do. low lubricity is a problem, so adding a small amount of canola would help, say 2-5%, or if you can get it,i use biodiesel, which also improves lubricity.
'91 Golf Cabrio 1.9TD
Reply #3July 17, 2007, 06:22:49 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: July 17, 2007, 06:22:49 am »
According to a service bulletin we sent out to our customers, ULSD is not only changed by the reduction of sulfur content, but by "eliminating fractions in the oil having a heavy molecular structure". This results in a "lower specific energy content than standard diesel fuel, in some cases by as much as 15%".  That would explain the mileage drop.
Calvin
91 VW Golf 1.6NA 5spd
Reply #4July 17, 2007, 08:03:34 am
myke_w
  • 1099
« Reply #4 on: July 17, 2007, 08:03:34 am »
I sell a lot of this additive to my diesel customers..
http://www.blauparts.com/proddetail.asp?prod=LM+2002
Claims to have additive that add increase lubricity etc. I can't really see any other good solution other than using biodiesel to offset lubricity and raise cetane rating
Reply #5July 17, 2007, 08:06:21 am
myke_w
  • 1099
Re: Results of Ultra Low Sulfur Diesel
« Reply #5 on: July 17, 2007, 08:06:21 am »
Eliminate it, it would have leaked eventually anyway. VW did away with it later in the idi series anyway.
Cylinder O-Rings?
Reply #6July 18, 2007, 01:07:15 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #6 on: July 18, 2007, 01:07:15 am »
Piston Rings?
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #7July 18, 2007, 01:31:42 pm
dlorimer
  • 31
« Reply #7 on: July 18, 2007, 01:31:42 pm »
Probably - I don't know what they're called.  The seal on the piston that keeps the exhaust from going into the oil pan.
Reply #8July 18, 2007, 08:55:26 pm
punkvideo81
  • 168
« Reply #8 on: July 18, 2007, 08:55:26 pm »
I just swapped from a 1.6 n/a to a 1.6 td and it developed a leak on the injection pump almost immediately (at the accelerator spring seal) . Could have been for many reasons, but one person I spoke to said the new ULSD was causing IP leaks in older pumps...hmm
It doesn't matter, though, because I decided to go buy a Giles pump, so things should be rip-roaring again soon.
'81 Caddy 1.6 TD
Reply #9July 18, 2007, 11:26:05 pm
« Reply #9 on: July 18, 2007, 11:26:05 pm »
well this has been covered many times over before, so let me explain why the pumps develop the leaks.
older diesel has aromatics in it that help 'swell' up the seals in the pump.  the way the ULSD is refined, removes these aromatics, thus the seals shrink once exposed to enough of the refined diesel.  and there you have it... that is why your pumps leak.
so just get your pump re-sealed, and be happy.
Reply #10July 19, 2007, 07:44:18 am
subsonic
  • 1836
« Reply #10 on: July 19, 2007, 07:44:18 am »
Does anyone know if the ULSD is being used in No.2 "red" diesel?
Reply #11July 19, 2007, 02:03:13 pm
dlorimer
  • 31
« Reply #11 on: July 19, 2007, 02:03:13 pm »
are there any additives that restore the aromatics neccesary for seal swelling?
Reply #12July 19, 2007, 02:22:40 pm
« Reply #12 on: July 19, 2007, 02:22:40 pm »
I think I was running ATF and it fixed my leak, or I was using it while the leak fixed itself. I can't remeber though, I've run so many additives. I usually run 1/6 quart/liter per tank when I was using it
Reply #13July 19, 2007, 04:45:47 pm
Infinitrium
  • 151
« Reply #13 on: July 19, 2007, 04:45:47 pm »
Quote from: "dlorimer"
Redline diesel fuel catalyst claims to help restore shrunken seals.
Reply #14July 19, 2007, 05:57:48 pm
knowtwodrugs
  • 46
« Reply #14 on: July 19, 2007, 05:57:48 pm »
Quote from: "subsonic"
From what I understand, the road fuel and the heating oil are exactly the same except for the dye that makes it red.  At least my bunny don't know the difference.  wink wink
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
 "Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
