Author Topic: injectors leaking at base (head)  (Read 5016 times)
July 10, 2007, 11:09:02 am
knowtwodrugs
  • 46
« on: July 10, 2007, 11:09:02 am »
Hey all, I just put new nozzles and whatnot and cleaned up my injectors while I was replacing my injection pump  :?   and now a couple are leaking right at the head.  Did I just not tighten them enough, or is there supposed to be sealent on the threads or something?  Thanks.
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
 "Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
Reply #1July 10, 2007, 02:09:30 pm
« Reply #1 on: July 10, 2007, 02:09:30 pm »
Did you hand-lap the three essential sealing surfaces on each injector before reassembly ??
I bet I know the answer ??!!!! :wink:
Otherwise:
- proper torque on injector piping ?
- proper torque on injector body ?
- new heat shield ?
- poor return tubing between injectors ?
Reply #2July 10, 2007, 04:19:51 pm
knowtwodrugs
  • 46
« Reply #2 on: July 10, 2007, 04:19:51 pm »
No I didn't lap them.   :(   I thought you just put them together the way they came apart?  I hope I didn't mess anything up too bad doing that.
1 - I don't know how to specify torque with an open-end wrench.  I only have a torque wrench that uses sockets.  How do you check the torque on the injector piping in that case?  I know too much pressure is bad, I only snugged them.
2- No, and I bet that's the problem.  My pops is bringing home the torque wrench tonight.
3- yes new heat shields
4- brand new tubing
If the motor fired and ran, am I OK on that lapping thing?  Or should I definately remove the injectors and take care of it?
609-835-0779
Reply #3July 10, 2007, 06:49:06 pm
« Reply #3 on: July 10, 2007, 06:49:06 pm »
Nah, you can't hurt these beasts... well, unless you don't put the timing belt on properly.
Looks like you've got most of your bases covered.
You need to see where they are actually leaking.... I use a can of brake cleaner and my air hose to clean them really really well... then you can see if the fuel is leaking from the very top (the connection with the tubing) or the between the body halves (lapping the components).
Yes  you kind have have to guess the torque with an open end wrench... the point is to tighten them enough but not so much that you break the fittings.
You do need to torque the heck out of the body halfs.
As you saw, there are no gaskets inside the injector... rather a reliance on very close tolerances, and as soon as you crack them open to replace the nozzle there's a good chance they won't go back exactly as they came apart... hence the need to hand lap.  Do a search here and at vwdieselparts.com and you'll find some good discussions on what and how to lap.
Reply #4July 11, 2007, 04:03:35 am
knowtwodrugs
  • 46
« Reply #4 on: July 11, 2007, 04:03:35 am »
Hmm well I put it all back together and torqued the injectors up to 60.  started her up and they're still leaking right at the head.  Could it possibly be the result of wear on the head or pistons or something that wasn't a problem with worn out nozzles?
609-835-0779
Reply #5July 11, 2007, 04:27:35 am
« Reply #5 on: July 11, 2007, 04:27:35 am »
by leaking at the head, you mean cylinder head? if you have leaks coming through there, then hmm... bad sealing with the heat shields maybe?  weird problem!
Reply #6July 11, 2007, 04:33:04 am
knowtwodrugs
  • 46
« Reply #6 on: July 11, 2007, 04:33:04 am »
Yup right at the cylinder head where they screw in.  =/
609-835-0779
Reply #7July 11, 2007, 01:33:44 pm
knowtwodrugs
  • 46
« Reply #7 on: July 11, 2007, 01:33:44 pm »
It does also release a sort of mist on #4 cylinder.  Could that be the boiling of the fuel releasing?  I suppose before I take it all apart again I could let it run for a bit and see what happens.
609-835-0779
Reply #8July 12, 2007, 03:28:24 am
knowtwodrugs
  • 46
« Reply #8 on: July 12, 2007, 03:28:24 am »
No luck on that.  My dad's gonna take the injectors to work today and see if anyone has any ideas.  He's a mechanic at the turnpike so we will see.
609-835-0779
Reply #9July 12, 2007, 08:59:08 pm
« Reply #9 on: July 12, 2007, 08:59:08 pm »
Quote from: "Vincent Waldon"
I'm sticking to my story...  ;-)
Reply #10July 13, 2007, 02:04:31 pm
Black Smokin' Diesel
  • 656
« Reply #10 on: July 13, 2007, 02:04:31 pm »
If it's leaking at the head, try to tighten them a bit more. I had the same problem when I replaced mine. I just tightened them more and they stopped leaking.
Reply #11July 13, 2007, 04:44:58 pm
  • 656
« Reply #11 on: July 13, 2007, 04:44:58 pm »
Quote from: "libbybapa"
The thing is, there are only two seams that can leak diesel fuel, the seam between the top half of the injector and the center "washer", and the seam between the "washer and the nozzle.  The fuel then leaks down inside the bottom half of the injector, past the heat shield and up the threads and out.  If you simply tighten the injector to the head, you might be able to stop the appearance of fuel leakage, by tightening the seal between the heat shield and the bottom half of the injector, but the fuel will continue to leak none-the-less.  It will fill the space between the nozzle and bottom half of the injector with fuel and gradually carbonize in to an incredibly hard resin.  Removal of the nozzle in the future will likely require a hammer.  Then again new injectors aren't all that expensive and cores are cheap.
Andrew
Doh :P
Would that cause white smoke at startup since there's fuel leaking into the cylinder?
Not 100% sure if it was diesel leaking because I used antiseize paste on the injectors before installing them. Maybe it was boiling and coming up making it look like a fuel leak at the head.
Reply #12July 13, 2007, 06:31:47 pm
« Reply #12 on: July 13, 2007, 06:31:47 pm »
I think you would get white smoke because you are losing compression to a leak, resulting in poor starting on the cylinder and an incomplete burn.
Like Andrew says, they can only leak diesel at two places... clean 'em with brake cleaner and see which.
If at the fitting, redo the connection looking for cracks in the tubing, dirt, or wrong torque.
If between the injector halves disassemble, lap, and reassemble.
Reply #13July 14, 2007, 04:30:27 pm
knowtwodrugs
  • 46
« Reply #13 on: July 14, 2007, 04:30:27 pm »
Well we got her running finally!  I don't know what he did that I didn't do, maybe he just cleaned the injectors better.  Thanks for the tip on the boiling especially, if I hadn't known that I would've freaked.  Thanks for all the help everyone.
609-835-0779
