smoke screw questions
Topic: smoke screw questions (Read 3641 times)
June 07, 2007, 09:45:38 am
larry104
June 07, 2007, 09:45:38 am »
What physically does the smoke screw do in the injection pump? I'm guessing it adjusts the starting position of the tapered valve. I undersand the star wheel adjusts diaphragm spring tension. If I want less smoke when I spool up the turbo, which way do I turn the screw and by how much? What is a typical amount of adjustment? T hank you.
June 07, 2007, 04:15:59 pm
Hillshy
June 07, 2007, 04:15:59 pm »
Hi Larry,
this was provided by Trev0rbr,
ok so here is the star wheel, the spring sits in it and it adjusts the tension on the spring, turning it to the left raises star wheel and the springs seat, this increases tension, turning it to the right lowers the star wheel and decreases tension, which increases fuel, as you can see i put marks on this as well so that it is much easier to see how many times i turned it
i really useful link, a good read.
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
June 07, 2007, 04:19:55 pm
Hillshy
June 07, 2007, 04:19:55 pm »
http://www.vwdiesel.net/phpBB/viewtopic.php?t=645&start=0&postdays=0&postorder=asc&highlight=
heres the link with pics
June 07, 2007, 08:04:28 pm
June 07, 2007, 08:04:28 pm »
it is well known that i am a pimp
June 09, 2007, 02:15:32 am
Hillshy
June 09, 2007, 02:15:32 am »
oook then,
so I hope that it was ok for me to PIMP you out to larry.
can I Get a cut, say 5%
June 09, 2007, 05:44:02 am
larry104
June 09, 2007, 05:44:02 am »
Thanks for the link, Hillshy. That's exactly what I needed.
June 09, 2007, 07:47:43 am
June 09, 2007, 07:47:43 am »
yes you can have 5%, besides i need someone to start slapping ***es for me... my hand just can't take the abuse.
June 09, 2007, 12:41:18 pm
Hillshy
June 09, 2007, 12:41:18 pm »
sweet glad to hear that!
batch slapping and 5% all in a dayz work my man :wink:
gotta go n pack my case, on holly bobs in the morning..
my lil sister is getting married this week in Jersey (a wee island just of the uk coast)
c you in a week guys
hillshy
June 09, 2007, 02:53:06 pm
June 09, 2007, 02:53:06 pm »
i just got back from andy2's place. he just hooked me up with some insanely cool mods!!! hooked up my solid state fuel pump (there was a small leak when checking to see how much fuel was being pumped... :shock:)
a little bit of tuning later (reduced fueling) 20 psi boost approx. absolutely no smoke out of my tailpipe! i am now a happy man! i hope to see some fuel mileage increases too!
i would have to say that andy2 is also a pimp! he works wonders with the starwheel adjustments! with the right adjustment and increased boost, you can pretty much eliminate off boost smoke, and increase on boost fueling.
June 09, 2007, 07:07:02 pm
rallydiesel
June 09, 2007, 07:07:02 pm »
So how much do you need to turn the starwheel bolt to see a change? Like a quarter of a turn or more like several full turns?
1991 Jetta TD - sold
2001 Golf TDI - Son's
June 10, 2007, 03:03:30 am
Benjamin
June 10, 2007, 03:03:30 am »
it all depends on your settings, a guy ever told me when the LDA go down to deep the pin toyour LDA can break. (i think this only can happen when you remove the plactic ring)
i turned my about 80degrees and it was realy better.
if you do starwheel adjustments just take a paper and count the clicks you make, so you can always go back to stock settings
Greetz, Benjamin
Must make +250hp
Reply #11
June 10, 2007, 07:48:47 am
Reply #11 on:
June 10, 2007, 07:48:47 am »
i mark mine with marker and just look at how many turns i do. i think thats alot easier than counting clicks.
