Author Topic: Hard Injector Lines......  (Read 2522 times)
January 19, 2007, 03:51:32 pm
Donny
  • 14
« on: January 19, 2007, 03:51:32 pm »
I got mine from e-bay and I am wondering if there is anything special I have to take into consideration with these?
Will I kill the injector pump if I don't find a way to prime them before trying to start the car.... seeing as they will be full of air. I have no clue what I have to watch for here. So any tips or hints are greatly appreciated.
Thanks.
Reply #1January 19, 2007, 04:09:23 pm
g-spec
  • 289
« Reply #1 on: January 19, 2007, 04:09:23 pm »
You dont have to prime them....the only thing i would do is put a drop of oil on all the conections (thread)...car should start no problem. It might take a sec or two longer. good luck
Michal
Reply #2January 19, 2007, 05:05:52 pm
« Reply #2 on: January 19, 2007, 05:05:52 pm »
hook up all the lines... tighten them up but leave the ends of the lines that connect to the injectors loose.  crank the motor until you see fuel come out.  tighten the lines up and enjoy!
Reply #3January 19, 2007, 09:32:37 pm
hillfolk'r
  • 1532
« Reply #3 on: January 19, 2007, 09:32:37 pm »
just never
never
never
bend a hi pressure diesel fuel injector line
the plating can fracture over time and be sent into your injectors
i know im always sayin that,but its a little known fact by most people
just keep the lines loose when you install them(loose on the injector)
and crank till fuel spits out
tighten them down,and crank till it fires off
Throttle cables ftw
Reply #4January 19, 2007, 09:50:05 pm
Donny
  • 14
« Reply #4 on: January 19, 2007, 09:50:05 pm »
Thanks a lot guys. Much appreciated.
Reply #5March 27, 2007, 10:10:53 am
g-spec
  • 289
« Reply #5 on: March 27, 2007, 10:10:53 am »
Are they not ceramic coated on the inside???? or at least some kind of coating???
cheers, Michal
