Author Topic: hybrid turbo setups  (Read 10277 times)
November 19, 2006, 07:17:11 am
scopefrfd
  • 289
hybrid turbo setups
« on: November 19, 2006, 07:17:11 am »
I have quite a few turbos laying around and I decided to go through them and rebuild what I have.   And some of the differences that I've noticed.
On the diesel side:
1.6td, t-3
volvo td t-3
1.9 kkk k03
audi kkk k-24
1.6td KKK k14
gas:
1.8t 20v KKK k03 150hp
1.8t 20v KKK k04 225hp
gas 8v turbo t-3 .42 a/r
audi 5000T k26
The volvo D24td turbo, although the a/r is the same as the vw units, the trims are larger.  The turbine and compressor wheels will not fit in the vw housings.  The wheels are much larger than the 1.6td units
The KKK K03 AAZ style 3-bolt, the gas KKK K03 has a much larger compressor wheel.
The gas t-3 turbo I have has the same a/r as the 1.6td, the turbine wheel is the same but it has larger compressor wheel.  It's actually a hair larger than the volvo td compressor wheel.
And the audi k26 has a much larger compressor wheel than the KKK K24.
Now, I was thinking of combining:
The KKK K03 diesel turbine with the audi K03 150hp gas compressor/housing.   It still should have the lighting fast spool up and a little more top end with the larger gas wheel.  Should be a nice turbo for a converted N/A 1.6 diesel or 1.6td, setup for max mileage
The 1.6td t-3, but swap in the compressor wheel/housing from the gas turbo t-3.  Again the compressor wheel is approx the same size as the volvo td.  A little slower spool up but more efficient under higher than stock boost levels.  May be a great turbo for 1.9 td's and tdi's or modded 1.6td's
The KKK k14, I'd like to get a k16 compressor side..the K24 nothing swaps over...I believe the audi k26 cold side should swap into a k24..that would make some serious boost with the right setup.
Wondering if anyone has already used any of these hybrids listed above and there findings.
Reply #1November 19, 2006, 10:30:29 am
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
hybrid turbo setups
« Reply #1 on: November 19, 2006, 10:30:29 am »
I was wondering about K14 and K24 hybrid, and you say that it isn't doable....I thought that while T2/T3 hybrid is possible, K14/K24 would also be possible...
Excuse me on my bad English
Reply #2November 19, 2006, 10:48:08 am
scopefrfd
  • 289
hybrid turbo setups
« Reply #2 on: November 19, 2006, 10:48:08 am »
the k14 and k24 have different shaft diameters..so I don't know how you could build a hybrid
Reply #3November 19, 2006, 11:05:37 am
andy2
hybrid turbo setups
« Reply #3 on: November 19, 2006, 11:05:37 am »
I've made a hybrid k24/k14 (k24 turbine with k14 compressor).Definitely a waste of time, stick with the 1.6 T3 and it will work great up to 22-24 psi no problem.T3 over k24 any day.
Reply #4November 19, 2006, 11:15:50 am
scopefrfd
  • 289
hybrid turbo setups
« Reply #4 on: November 19, 2006, 11:15:50 am »
I would imagine that setup would be counter productive, it think the k03 td turbine and gas k03 compressor would be great for an eco diesel
"I've made a hybrid k24/k14 (k24 turbine with k14 compressor).Definitely a waste of time, stick with the 1.6 T3 and it will work great up to 22-24 psi no problem.T3 over k24 any day."
Reply #5December 29, 2006, 07:12:33 pm
deezul ryan
  • 24
    • http://www.dieseldude.com
hybrid turbo setups
« Reply #5 on: December 29, 2006, 07:12:33 pm »
has anyone tried a k24/k26 combo?  k24 turbine with a k26 compressor?
i will try this soon after i get a rebuild kit.
94 jeep YJ 2.4 TD (vw diesel powered)
81 vw pickup 2.0 16v dual carbs NOS soon to be TDI-M powered
80 vw pickup 1.5 TD
53 Studebaker M35 7.8 TD (23,030 GVWR)
Reply #6December 30, 2006, 08:25:49 am
andy2
hybrid turbo setups
« Reply #6 on: December 30, 2006, 08:25:49 am »
Dr Diesel has ran that combo I can't remember the results of it though?
Reply #7January 27, 2007, 11:43:58 am
andysimpson
hybrid turbo setups
« Reply #7 on: January 27, 2007, 11:43:58 am »
Quote from: deezul ryan
Have you tryed this? I have a 24 and a 26 and am tempted to make a 24/26
Reply #8January 27, 2007, 03:48:34 pm
scopefrfd
  • 289
hybrid turbo setups
« Reply #8 on: January 27, 2007, 03:48:34 pm »
I'd love to see someone try a k24/k26 hybrid...especially on a tdi or 1.9td
Reply #9January 28, 2007, 05:33:18 am
aidan
hybrid turbo setups
« Reply #9 on: January 28, 2007, 05:33:18 am »
Are any parts between the K14 and the 1.8T K03 interchangeable? I have a 1.8T K03 sat in the garage doing nothing, and the K14 is on my GTD.
Maybe K14 turbine and turbine housing on the K03 compressor, compressor housing and centre section?
