Author Topic: Pump Mods/Gov Mod?  (Read 7612 times)
November 16, 2006, 02:28:53 pm
foxracer1
  • 991
Pump Mods/Gov Mod?
« on: November 16, 2006, 02:28:53 pm »
So i did the Gov mod. I used a piece of 1/4" stainless tube to eliminate the intermediate spring and to preload the main spring 1/4". Now it idles fine crusies fine. But when i mat it the it doesn't pull as hard as say 85% throttle. I feel it is over fueling way to much cuz i'll get what looks like white smoke. I backed the full load fuel off but it just took away from the first 50% of the throttle then it was the same as before throught the rest of the travel.
The EGTs never went above 1100 but was around 700 just cruising at 45mph. I installed a SCed Corrado manifold with a modified dual downpipe. I put my probe in the port on the manifold that is in between the two ports. What are the usual temps to expect out of the egts?
I haven't had much road testing so next week when i do more i'll post more but if anyone has delt with the similar please let me know.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #1November 20, 2006, 11:28:14 am
foxracer1
  • 991
Pump Mods/Gov Mod?
« Reply #1 on: November 20, 2006, 11:28:14 am »
anyone???
91 S10 305 TPI T56
Reply #2November 21, 2006, 05:17:11 pm
AdAm84
Pump Mods/Gov Mod?
« Reply #2 on: November 21, 2006, 05:17:11 pm »
white smoke isn't good.
Reply #3November 23, 2006, 07:06:59 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
is it Turbo on NA?
« Reply #3 on: November 23, 2006, 07:06:59 pm »
hi
u didn't mentionif it's a turbo or not?
if u have the non turbo then don't do the gov mod
Giles
Reply #4November 23, 2006, 08:39:58 pm
foxracer1
  • 991
Pump Mods/Gov Mod?
« Reply #4 on: November 23, 2006, 08:39:58 pm »
Yup its a non turbo. Whats the problem with doing it to a N/A?  I have a Pyro, and all its doing is continuing to add fuel until the higher rpms. If there is more to know please let me know. I redid it with a shorter piece and it seems to run good really strong in the low to mid rpm, combined with the corrado manifold and downpipe. I just need to work on the intake.
91 S10 305 TPI T56
Reply #5November 26, 2006, 04:08:18 am
Hillshy
  • 103
    • http://www.hillshy.co.uk
Pump Mods/Gov Mod?
« Reply #5 on: November 26, 2006, 04:08:18 am »
Hi all,
i'd also like to know why the Gov mod shouldn't be done on a N/A motor?
Hillshy
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #6November 26, 2006, 06:36:12 am
  • 221
problems
« Reply #6 on: November 26, 2006, 06:36:12 am »
u shouldn't do the part load gov mod since it changes the fuel
delivery the wrong way for a NA engine.
but do the max rpm gov mod though
Giles
Reply #7November 26, 2006, 09:04:37 am
Benjamin
  • 485
Re: problems
« Reply #7 on: November 26, 2006, 09:04:37 am »
Giles
so, only a stronger preload for the main spring, and not shimming the intermediate spring?!?
Greetz, Benjamin
Must make +250hp
Reply #8December 14, 2006, 01:31:33 pm
foxracer1
  • 991
Re: problems
« Reply #8 on: December 14, 2006, 01:31:33 pm »
Quote from: Giles@superiorFuelInj
Giles
That would make sense on the way the ole N/A is runnin. gonna switch it out this weekend. So the max rpm spring is the longer one?
91 S10 305 TPI T56
Reply #9December 14, 2006, 03:24:40 pm
hipifreq
  • 89
Pump Mods/Gov Mod?
« Reply #9 on: December 14, 2006, 03:24:40 pm »
Sounds like your timing is retarded.
Andrew
*COUGH*
Don't you mean "your timing has an intellectual disability?"
 :wink:
Reply #10December 18, 2006, 05:04:48 pm
dover
  • 18
Re: problems
« Reply #10 on: December 18, 2006, 05:04:48 pm »
Giles
OK... I'm a newb with an '85 Golf NA (with 1 leaking pump installed and several old "spares")
BUT: I have a seal kit  (local Bosh service center), the Bosch IP pdf (open... can't re-find the link), the "Governor Mod" and the "Governor Mod - Clarified" open and
I'm a little confused. The first one looks like a TD IP (I got no diaphragm on mine). Am I going for the second one?
Just the intermediate spring or just the shims on the big spring?
Is this the figure I need to fully grasp:
I don't want to race but I hate it when they show up in the rear view on long climbs.
If I do manage to up the power will methanol/water injection make any difference in an N/A?
BD BD
Reply #11December 19, 2006, 12:31:17 am
Pump Mods/Gov Mod?
« Reply #11 on: December 19, 2006, 12:31:17 am »
what is the dif between a part load gov mod and a max rpm gov mod? or did I miss a simple thing? :?
Reply #12May 25, 2007, 04:28:10 am
Bean
Pump Mods/Gov Mod?
« Reply #12 on: May 25, 2007, 04:28:10 am »
Anybody cleared this up yet?
Does giles mean that you should only pre-load the main spring and leave the intermediate in tact for a N/A diesel?
Reply #13May 25, 2007, 11:58:38 am
Baxter
Pump Mods/Gov Mod?
« Reply #13 on: May 25, 2007, 11:58:38 am »
I tried this.
I have a NA caddy, I did both mods, it was okay, but as stated it didn't feel as quick when booted.
So, I undid one of the mods and it worked a teat.
Caddy now pulls harder all the way up the rev range.
Reply #14June 06, 2007, 09:03:19 am
Bean
Pump Mods/Gov Mod?
« Reply #14 on: June 06, 2007, 09:03:19 am »
Which mod did you undo? Shimming/replacing the intermediate spring, or shimming the main spring?
My pump is leaking and I think the O ring is probably shot, so I want to do this when I replace that but I need to be sure which mod to do before I pull things apart.
Cheers   :wink:
