Author Topic: '97 TD AAZ - Weird stumble. Any ideas?  (Read 7810 times)
Reply #15October 30, 2006, 10:24:20 pm
iggi
  • 33
« Reply #15 on: October 30, 2006, 10:24:20 pm »
Well..  the jetta and I are back home.
On Sunday I stripped off the belt cover/etc and gave the belt/crank pulley etc a good inspection.  The belt is a bit abused but decently tight.  No wobble or looseness detected on the crank pulley.
So..  I drove it the 750K home.  Mostly at 80-85 kph which made it a long drive but I felt confident that if I babied it there wouldn't be a problem.
I added some ATF to the tank before I headed home and about 3/4's of the way home it was running noticeable smoother.
My new belt, crank bolt, etc should be here in a couple days and then it's all heading off to my mechanic.  It'll be interesting to see what he say's once it's apart.
'97 Jetta GL TD
'87 Vanagon Westy
Reply #16October 31, 2006, 07:06:35 am
QuickTD
  • 1156
« Reply #16 on: October 31, 2006, 07:06:35 am »
Everything I have ever read indicates that once the pulley is replaced with another AAZ one, it fails in short order even if there wasn't a problem previously. They all fail eventually
 Mostly true, but there are exceptions. If the pulley has never come loose in the past and there is no play in the keyway, a new pulley and bolt can be installed along with other improvements (one way alternator pulley, new harmonic balancer) and it will survive. I have fixed several of these engines but my own remains stock with 308000km on it.
 That said, if the crank shows any wear once its apart I would highly recommend the TDI pulley fix. It'll seem pretty cheap later when you have to replace the head...
Reply #17October 31, 2006, 07:24:16 am
iggi
  • 33
« Reply #17 on: October 31, 2006, 07:24:16 am »
Quote from: QuickTD
Yup.
It all depends on how it looks once it's all apart. Hopefully the crank is good.
'97 Jetta GL TD
'87 Vanagon Westy
