Author Topic: 2.4L D24T Oil Pump OE Number interchangeability  (Read 10386 times)
December 04, 2025, 08:05:12 am
DieselScout
  • 1
« on: December 04, 2025, 08:05:12 am »
I believe my current pump may be the cause of the lower than ideal oil pressure.
So I am looking for a replacement oil pump for a D24T motor. (VW 6 cylinder used in a Volvo 240/740)
I found a NOS pump on Ebay with a part number of “069115109G,” that says it’s for the Audi 5000 l5.
Where-as the part number cast on the pumps that I have are “069115109."
Does the letter at the end signify anything,” such as a different capacity/pressure/flow rate?
Or should they all be interchangeable?
« Last Edit: December 04, 2025, 08:13:48 am by DieselScout »
Reply #1December 04, 2025, 11:13:13 am
Dennis Froelich
  • 256
Re: 2.4L D24T Oil Pump OE Number interchangeability
« Reply #1 on: December 04, 2025, 11:13:13 am »
Here are the part numbers that I found for that exact engine...
069 115 105J
069 115 105Q
075 115 105A
VW Classic Parts has these. 069 115 105Q is a direct replacement. The oil pickup tube is nearly 36 inches long.
« Last Edit: December 04, 2025, 11:17:36 am by Dennis Froelich »
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #2March 25, 2026, 09:50:32 am
Michael Zill
  • 1
« Reply #2 on: March 25, 2026, 09:50:32 am »
Hello what should i do I have a 069115109 in Brand new original and i dont know if i can put it in my 2.4 liter VW 6 zylinder Diesel does anyone know anything?  Please give me a Solution
Michael
Reply #3April 09, 2026, 12:46:45 pm
w1004thw
  • 4
    I spend 2 mins using a tool, 2 hrs looking for it
« Reply #3 on: April 09, 2026, 12:46:45 pm »
If the eBay pump is truly an NOS 069115109G, it should physically fit and work on your D24T.
If you want absolute certainty, check the pressure relief spring spec or ask the seller if it’s the “same flow spec” as your original pump
