Author Topic: LR Pump Innards into a MK4 Housing?  (Read 8165 times)
October 09, 2023, 10:47:28 am
jhax
  • 324
« on: October 09, 2023, 10:47:28 am »
Hello,
I have found myself in a situation whereby I have a cracked LR pump (on the housing where the timing pin is inserted) and a MK4 pump that had gasoline run through it. Can I just take the innards from the LR pump and install them in the MK4 case? Can I swap the electronic LDA on the mk4 pump with the mechanical one on the LR?
Thank you,
Justin
Reply #1October 11, 2023, 05:36:46 pm
  • 2920
Re: LR Pump Innards into a MK4 Housing?
« Reply #1 on: October 11, 2023, 05:36:46 pm »
 I think the TDI pumps have a different way of governing.
 The LR pump is machined for the flyweights type governor.
Tornado red, '91 Golf 4 door,
