Author Topic: AAZ K14 turbo on 1.6td  (Read 4596 times)
September 03, 2023, 03:28:09 pm
BuckyMK2
  • 27
« on: September 03, 2023, 03:28:09 pm »
I've searched a lot but cannot find a clear answer. Does the K14 from the AAZ 1.9td bolt up to the 1.6td manifold? I know I would need a different oil return line, but is that the only difference?
Reply #1September 07, 2023, 06:18:58 am
oblique
  • 317
    Diesel while you can.
Re: AAZ K14 turbo on 1.6td
« Reply #1 on: September 07, 2023, 06:18:58 am »
The trapezoid shape of the flanges will bolt up however AAZ manifold flange is at a slightly different angle with reference to the back of the head vs. 1.6TD manifold. Also the turbo itself may interfere with heatshields (depending how its clocked or where the wastegate sits, etc) and may not align properly with intake manifold and rubber connector. AAZ intake manifolds have a different port shape if you wanted to use that on the 1.6td head, may or may not bother you. Then you have to deal with oil supply and return.
Folks have done it, im sure, maybe someone will chime in.
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
