Author Topic: AAZ Vanagon boost peaks holds for a second then drops off after adjusting fuel  (Read 10298 times)
Reply #15July 03, 2023, 10:01:52 pm
  • 2932
Did you check your local bosch service center?
Reply #16July 06, 2023, 06:23:20 am
RockOcean
  • 139
Unfortunately I can not find a Bosch Service Center anywhere close to me in South West Montana. Seems like the best nozzle options are DN0SD297 or DN0SD308 since the Merc nozzles are not designed for our pre chambers from what I have heard. I still don't see these readily avail anywhere in the US but there are a good number of sources in Europe so I should be all set.
Reply #17July 20, 2023, 05:37:02 am
RockOcean
  • 139
My IP rebuilder Brian at Omega Fuel Injection informed me that the DN0SD297 nozzles do not work in the AAZ injector. Giles from Performance Diesel also confirmed this. I finally got a set of DN0SD308 / 0 434 250 169 from FLAG Germany.
