Author Topic: Water Injection  (Read 33155 times)
Reply #45August 04, 2006, 08:28:44 am
BellCityDubber
  • 251
Water Injection
« Reply #45 on: August 04, 2006, 08:28:44 am »
Quote from: "Benjamin"
those pics i ever promised  :oops:  , this is the angle (of my 300cc injector)
@BellCityDubber: did you tried something out with a CIS pump?
Greetz, Benjamin
No, I havent had the time to mess around and experiment yet... I've been working towards getting my 2nd vehicle on the road, and trying to get boatloads of homework finished.. but if I ever come across some time and some equipment to experiment with, I'll surely let people know...
thanks for the pictures, I really like that spray pattern
Reply #46August 29, 2006, 12:00:34 pm
BellCityDubber
  • 251
Water Injection
« Reply #46 on: August 29, 2006, 12:00:34 pm »
Okay, I've finally got some parts that I can play with
I have another intake I can tear apart/open.. I've got another washer resivoir and washer fluid pump, I've got wires (no switch :S )
I've got a bit of tubing.... annnnnnnd..... a NOS fogger....
I'm going to see how well the pump will pressurize and how well the NOS fogger will atomize/fog.
and I'm also toying with the idea of also running an intercooler as well...
I'll be doing some mucking around with this gear this weekend, I'll let people know
Reply #47August 29, 2006, 12:49:18 pm
Benjamin
  • 485
Water Injection
« Reply #47 on: August 29, 2006, 12:49:18 pm »
let the pump run for 1minit with the nozzle, place the nozzle in a bottle, you can see how much cc/min it flows, if its to much, you got a problem.
Greetz, Benjamin
Must make +250hp
Reply #48August 30, 2006, 10:31:26 am
greggearhead
  • 153
Water Injection
« Reply #48 on: August 30, 2006, 10:31:26 am »
Another important factor is that the nozzle is spraying into a pressurized intake.  If your washer pump makes 7psi, when the boost goes over 7psi, there will be basically no spraying!
Here is a pic of one of our nozzles showing what a specialized design and more pressure can get you.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
Reply #49August 30, 2006, 01:45:06 pm
BellCityDubber
  • 251
Water Injection
« Reply #49 on: August 30, 2006, 01:45:06 pm »
Quote from: "greggearhead"
I'm a poor starving student, as much as I'd love to get a nozzle like that, and a higher powered pump.... I'm broke, so I'll scavange up whatever parts I can to make something that will do the job.
as for spraying into the intake... I wont be spraying into the pressurized side, I'll be spraying into the turbo intake as per hillfolk'r's configuration...
I have similar parts and pieces so it SHOULD work somewhat similar to his design and perhaps be effective to some degree.
Reply #50August 30, 2006, 03:58:00 pm
Water Injection
« Reply #50 on: August 30, 2006, 03:58:00 pm »
Quote from: BellCityDubber
Quote from: greggearhead
I think for efficiency wise, using the high pressure side would be most beneficial.
this kit seems pretty cheap:
http://cgi.ebay.com/ebaymotors/WATER-INJECTION-Alcohol-Intercooler-Turbo-Supercharger_W0QQcmdZViewItemQQcategoryZ42604QQihZ013QQitemZ230022320454QQrdZ1QQsspagenameZWDVW
Reply #51August 30, 2006, 06:35:46 pm
BellCityDubber
  • 251
Water Injection
« Reply #51 on: August 30, 2006, 06:35:46 pm »
Quote from: "jtanguay"
That kit is 200 bucks before shipping.
I have a problem getting 20 bucks
and.... you need a credit card or some method of payment (I hate paypal, I got screwed once)..
sooo... ebay buys are NOT an option.
neither is BUYING a kit.. which is why I'm attempting to BUILD one from scratch, I figure if hillfolk'r can do it... what's stopping me from doing the same?
annnnywho..
I tested the volume of the pump, it delivers about 1&1/3 cup of fluid in 10 seconds... if it's injected into the intake where the popoff valve was, I'm sure the turbo will be able to aid in atomization on top of running it thru a NOS fogger.
Reply #52August 30, 2006, 06:53:12 pm
Water Injection
« Reply #52 on: August 30, 2006, 06:53:12 pm »
i;m gonna try messing with a windex style nozzle and see what happens,  and thinking maybe a paint nozzle, and if they don't put out enough, then i'll used more than one...
Reply #53August 31, 2006, 08:07:52 am
Water Injection
« Reply #53 on: August 31, 2006, 08:07:52 am »
Quote from: Trev0rbr
like an airbrush nozzle?  not a bad idea.
All you would really need to make your homebrew water injection system would be the washer pump from a vw, and a good nozzle. (very cheap if you know of a vw just sitting around...)
Go to home depot in their lawn section I think.  They sell these little nozzles for people growing stuff (you can either have a jet like spray, or a misting spray.  I'd go with misting...)
I think the price is around 2-3 bucks and you could hook it all up quite easily to the washer pump.
Reply #54August 31, 2006, 03:45:32 pm
greggearhead
  • 153
Water Injection
« Reply #54 on: August 31, 2006, 03:45:32 pm »
Oh I am not trying to convince you to buy a kit - I remember only too well eating noodles out of a bag for months because I bought some car parts.  Ah, college.
I was just trying to show what you can acheived with a better design and more pressure - something to shoot for, maybe.
Reply #55September 01, 2006, 04:06:47 pm
hillfolk'r
  • 1532
Water Injection
« Reply #55 on: September 01, 2006, 04:06:47 pm »
if you ran a metal tank,you could run a boost line to the tank,so the pressure in the bottle is "equal" to the intake,and voila your 7 psi pump squirts no matter what the boost pressure is
why dont you guys just use my setup? it cost like 10 bux,and it works good,i use it as a passing gear on the hiway,lol
i just keep my foot steady,and pull out to pass,i just activate the water injection
Throttle cables ftw
Reply #56September 02, 2006, 05:13:14 am
Benjamin
  • 485
Water Injection
« Reply #56 on: September 02, 2006, 05:13:14 am »
Smart  :D
Greetz, Benjamin
Must make +250hp
Reply #57September 02, 2006, 07:17:08 am
BellCityDubber
  • 251
Water Injection
« Reply #57 on: September 02, 2006, 07:17:08 am »
Smart  :D
Hillfolk'r is the man
Reply #58September 02, 2006, 10:48:17 am
hillfolk'r
  • 1532
Water Injection
« Reply #58 on: September 02, 2006, 10:48:17 am »
ill haveta try and draw a pic from my turbo book on this water injection setup with a pressurized bottle
ya need maybe a check valve and a vent,i cant remember,ill haveta get the book later :wink:
Throttle cables ftw
Reply #59September 05, 2006, 11:01:23 am
BellCityDubber
  • 251
Water Injection
« Reply #59 on: September 05, 2006, 11:01:23 am »
Well, I've done some tests this weekend and used my setup.. the pump is good (1&1/3 cup / 10 sec) I'm using a mk1 washer bottle due to it's size advantage (I dont mind refilling it) my hoses look good and the length is nice for where I am going to mount the bottle.
I tried using my NOS fogger.. but it wasnt as effective as I would have thought. the pattern was right, but little to know atomization/misting
so I'm going to try a few other types of nozzles...
e.g. carb jets, etc
