Author Topic: has anyone raced there diesel in the 1/4 mile?  (Read 8981 times)
Reply #15September 23, 2010, 07:33:09 am
BellCityDubber
  • 251
Re: has anyone raced there diesel in the 1/4 mile?
« Reply #15 on: September 23, 2010, 07:33:09 am »
I raced my 4dr mk2 Jetta 1.6TD in the 1/4 mile about a month or so ago...
came up with a 17.2
mods:
intercooler
Performance Diesel pop-off valve blockoff plate
Performance Diesel (Giles) Superpump
Performance Diesel Balanced injectors
lightened flywheel
Eurodrive unsprung 4 puck clutch
Uprated pressure plate
running 25psi
Full interior, with subs, amps, and lawnchairs for car shows in the back....
Reply #16September 23, 2010, 12:44:38 pm
Powered by Spearco
  • 1203
« Reply #16 on: September 23, 2010, 12:44:38 pm »
I ran a 17.6 in the 1/4 mile.
1.6/1.9 combo engine.
Giles super pump
AAZ injectors w/GTD nozzles
Merc. T3 turbo
Corrado intake
2.5 inch turbo back exhaust
FMI
MK4 TDI trans. w/Peloquin diff.
13" tires  :D.
Oh, and 10 PSI of boost. Soon to be 30 PSI  :o.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #17September 23, 2010, 01:04:51 pm
Powered by Spearco
  • 1203
« Reply #17 on: September 23, 2010, 01:04:51 pm »
This is not a 1/4 mile truck but still cool to be able to do 137MPH!!! :o in a mile.
Twin turbo ALH MTDI.
'13 Golf R:. Tuned
'98 Puch G320
Reply #18September 23, 2010, 01:08:26 pm
BellCityDubber
  • 251
« Reply #18 on: September 23, 2010, 01:08:26 pm »
CRANK IT UP!! :D
Reply #19September 23, 2010, 01:26:11 pm
Powered by Spearco
  • 1203
« Reply #19 on: September 23, 2010, 01:26:11 pm »
Its just fresh from a rebuild. Only 300ish miles on it. Need to do an oil change and switch to synthetic oil.
I need a MBC or just cap off the wastegate ref. and let my foot be the boost controller  ;D.
'13 Golf R:. Tuned
'98 Puch G320
Reply #20September 23, 2010, 02:15:49 pm
« Reply #20 on: September 23, 2010, 02:15:49 pm »
1.6td in my 81 coupe, 2.25 tt exhaust, lots of fuel, and 25-30 psi, and a slipping clutch i did 16.5 the first time i ran it, the next time i ran it i added a cone filter and only had 1/4 tank of fuel, and i did 16.2 this was with a gtech.  which are supposed to be accurate for ets but not for trap speed, i think it said my trap was like 92 haha
Reply #21September 24, 2010, 04:14:07 am
MJF
  • 581
« Reply #21 on: September 24, 2010, 04:14:07 am »
Audi 80 1,6td. 10mm pump, gt2359v etc... 15,54/93mph. That was best at real track, best gtech later 15,0. Later with 12mm pump and in mk1 Scirocco, 14,5/103mph at track. FWD sucks at starts, now waiting to get my quattro at track :)
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #22September 26, 2010, 09:28:06 pm
Aki-76
« Reply #22 on: September 26, 2010, 09:28:06 pm »
pretty good  :o
mantorp,sweden i run 1.3bar boost 1/8mile at 9.5sek,
Highest boost what i use my car is 3bar or 45psi.
« Last Edit: September 26, 2010, 10:23:24 pm by Aki-76 »
Reply #23September 27, 2010, 02:44:16 pm
« Reply #23 on: September 27, 2010, 02:44:16 pm »
these numbers are kind of disappointing actually... decently built 16vs can run 14s
Reply #24September 27, 2010, 02:46:51 pm
« Reply #24 on: September 27, 2010, 02:46:51 pm »
Yeah my buddy troy has an 8v that will do a 12.19  109mph. CIS too. He is more of a nut than I am :D
Reply #25September 27, 2010, 03:06:33 pm
« Reply #25 on: September 27, 2010, 03:06:33 pm »
damn turbo or nitrous?  or is he a crazy crazy na guy
Reply #26September 27, 2010, 03:20:05 pm
MJF
  • 581
« Reply #26 on: September 27, 2010, 03:20:05 pm »
These are not drag racers and fwd sux at starting line => baaaad elapsed times. Itīs trap speed that counts with these vehicles :P
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #27September 27, 2010, 03:36:30 pm
Alleslowbuged
  • 270
« Reply #27 on: September 27, 2010, 03:36:30 pm »
I have done a couple of run`s with my bmw (E28; 524TD) and also with my VW Golf MK2 with AAZ engine.
On G-Tech run`s i have make 15,1s with both cars for the 1/4 mile, with the BMW i have just done a 15,2s
on last saturday (the trac is straight upwards), with good start a 14,9 should be possible.
The bmw is (except of the engine) stock condition, which means big leather seats, air condition, power steering,
sun roof, central locking, etc..).
The VW has only done a 16,38s on sunday on the same trac, which is nearly no progress to last year results.
I has done a 9,3s on the 1/8 mile (same trac) for 2 month, but have lost top end power by the last pump
modifcation. I will go ahead with a 12mm plunger as next pump evolution and hope to bring back the top end
power, which i have had before. Also the turbo (T03) is in bad condition and need extremly long to spool, i drive
without wastegate actuation, so boost is between 12-14 psi in first and second gear and 22psi on higher gears.
Best Regards
Alleslowbuged
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #28September 27, 2010, 07:45:17 pm
« Reply #28 on: September 27, 2010, 07:45:17 pm »
Pretty much all stock stuff internally, but external:
Intercooled, some volvo turbo, and used to do nitrous as well, but since the volvo turbo no nitrous. He also welds the spider gears in the trans solid, has a wicked 4 puck solid clutch, and some drag slicks. Some special suspension stuff to help him corner when not drag racing and some other stuff to help him launch.
The inside is gutted except for a the gauges, wiring, and 2 seats. No carpet or roof. I think it weighs a little less than 1600lbs.
Edit*he could be doing better I believe if he ran more cam. He has the stock GTI grind and all the bigger ones he tried he didn't like. Not because of performance, but around town drivability was poor. With his clutch and welded spiders it is hard to drive in say a drive through. With the bigger less vacuum, tough idle cam it is pretty much a park and walk in car and he doesn't want that. *
« Last Edit: September 28, 2010, 05:08:53 am by theman53 »
Reply #29September 28, 2010, 01:44:02 am
stewardc
« Reply #29 on: September 28, 2010, 01:44:02 am »
A local here wirth a Scirocco powered by an AAZ has run 13.7 and is shooting for 12s.
