Author Topic: Clutches  (Read 3306 times)
May 05, 2006, 06:05:10 pm
BellCityDubber
  • 251
Clutches
« on: May 05, 2006, 06:05:10 pm »
Seeing as my clutch is slipping, I'd need some info
Is there any difference in pressureplates/clutch/flywheel... from a 8v gasser to a 1.6L MF code TD?
 (I think the flywheel is different)
or are they in fact the same?
Reply #1May 05, 2006, 07:51:49 pm
SMOKEYDUB
  • 630
Clutches
« Reply #1 on: May 05, 2006, 07:51:49 pm »
you can use a flywheel and pressure plate from the 2l 16v gasser that came in the gti golf. they are 210 mm compared to the stock td one measuring at 200 mm.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2May 05, 2006, 08:56:35 pm
hillfolk'r
  • 1532
Clutches
« Reply #2 on: May 05, 2006, 08:56:35 pm »
i have posts on this subject,run a search,and lemme know if you find 'em!!!if not ill go into detail,,i got(had) a centerforce dualfriction in my jetta ,,,,,it was nice(it doesnt have the little weights though,its "like " a stocker,and the disc cush drive springs are doubled up,less lash,its nice,lemme know if you dont find my 210mm diesel clutch setup posts,there are some pitfalls,like having to redo the timing mark,basically...have fun!! :idea:(use a clutch from a 83-4 rabbit gti,basically)
Throttle cables ftw
Reply #3May 05, 2006, 11:16:52 pm
BellCityDubber
  • 251
Clutches
« Reply #3 on: May 05, 2006, 11:16:52 pm »
I've heard of the 16v pp/flywheel trick
but chapter 5 section 2 of the bentley
(I dunno if the link will work, but I'll post it anways)
http://ep0niks.ctech.ca/vw/eva2/TM01/ch5.2.html
says the bolt pattern is different.... is this correct?
I'll take a search for some of your earlier posts hillfolk'r.... I'll get back to you on that..
thanks guys
Reply #4May 06, 2006, 09:26:27 am
Kudagra
  • 738
    • www.no-coast.com
Clutches
« Reply #4 on: May 06, 2006, 09:26:27 am »
how about a diesel vanagon flywheel?
I guess its a 215mm...will that fit in a 020 trans?
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #5May 06, 2006, 11:57:32 am
VentoTD
  • 34
Clutches
« Reply #5 on: May 06, 2006, 11:57:32 am »
I'm using a sachs racing clutch (pressure plate and sinter disc). It's very smooth and feels like the stock one. Another good thing about it is that it lasts longer than the 020 gearbox (450nm). I've had to toss my tranny in the trash can, but the clutch is fine.
