Author Topic: oil cooler question.  (Read 4876 times)
April 27, 2006, 09:09:25 pm
SMOKEYDUB
  • 630
« on: April 27, 2006, 09:09:25 pm »
On the turbo diesel 1.6 on the oil filter housing they have a oil heater? Would it be effective to loop those 2 lines and run a seperate pump and pump it through a cooler up front? has anyone done this yet?
Thanks
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1April 27, 2006, 11:45:02 pm
« Reply #1 on: April 27, 2006, 11:45:02 pm »
IMO the most effective thing you can do with VWs heat exchanger is move it to the trash.
It takes under 3 minutes to piss all your oil out the seam
or maybe it gets oil in your water.
or maybe the coolant hose pops.  VW says replace it with a new $370 form them unit every time you work on the engine because it is no good.
Reply #2April 28, 2006, 04:53:05 am
andy2
« Reply #2 on: April 28, 2006, 04:53:05 am »
I'm running a bypass adapter thing that replaces the heat exchanger.My cooler is mounted where an A3 TDI intercooler would be.
Reply #3April 28, 2006, 05:36:16 am
« Reply #3 on: April 28, 2006, 05:36:16 am »
http://www.autotech.com/prod_engine_oilcooling.htm
Setrab coolers are the bomb.  Bit pricey though.  I'm good friends with the USA rep for Setrab, I might be able to get a deal together.  They have some really impressive intercoolers as well, including a very old-school water-to-air unit that was a prototype for an early turbo kit for the rabbits.  If anyone is interested, I can persue this a little more and get some kit pricing together.
84 Scirocco 8v
00 Camaro L36 M49
Reply #4April 28, 2006, 09:13:29 am
jackbombay
  • 599
« Reply #4 on: April 28, 2006, 09:13:29 am »
Quote from: "lord_verminaard"
   If you are on a budget you can get very near the same thing from a Volvo 240 gasser turbo, I thiink the thermostat in thoes is 190 F though, IIRC. The  lines are about 2 feet long, IIRC. I'm pretty sure the oil filters are the same diameter.
Reply #5April 28, 2006, 04:07:32 pm
« Reply #5 on: April 28, 2006, 04:07:32 pm »
I am using one form a 740 Volvo gas turbo..
thermostat says 100C.
The colored Oring from the dealer is supposed to be best, it was about$8 and green if I remember right.
Get the spin on pipe from the donor car, or you will have to buy an expensive tap like I did.  Saab rubber cooler lines bolted on in place of the original hardlines, and have banjos on the cooler end.  I had to get the rubber replaced at a hydraulic shop though.
Reply #6April 28, 2006, 04:39:32 pm
hillfolk'r
  • 1532
« Reply #6 on: April 28, 2006, 04:39:32 pm »
one good thing about the factory cooler,is it helps the oil come up to temp qwicker,,,very critical for a turbo,,keep it on there,and add an aux cooler
Throttle cables ftw
Reply #7April 28, 2006, 05:09:22 pm
jackbombay
  • 599
« Reply #7 on: April 28, 2006, 05:09:22 pm »
Quote from: "745 turbogreasel"
  That's a little on the hot side, I wonder if the 240 really was 190* F (according to bently) or if it was a different part, or if I just remembered it wrong...
Reply #8April 28, 2006, 05:10:00 pm
jackbombay
  • 599
« Reply #8 on: April 28, 2006, 05:10:00 pm »
Quote from: jackbombay
Quote from: 745 turbogreasel
  That's a little on the hot side (212* F), I wonder if the 240 really was 190* F (according to bently) or if it was a different part, or if I just remembered it wrong...
Reply #9April 28, 2006, 07:11:02 pm
« Reply #9 on: April 28, 2006, 07:11:02 pm »
yeah the only thing keeping it from boiling over would be the anti freeze...
Reply #10April 28, 2006, 07:12:48 pm
« Reply #10 on: April 28, 2006, 07:12:48 pm »
Quote from: jtanguay
[/list]
Reply #11April 29, 2006, 03:01:42 am
TDForNow
  • 131
« Reply #11 on: April 29, 2006, 03:01:42 am »
Quote from: hillfolk'r
Actually, the stock ones are great for stock motors, the better ones for modded motors is the stock cooler on the 04-05 passat 2.0 TDI's. It's twice as big and like hillfolk'r said, not only will it keep your oil cool, it'll warm up your oil quicker and more importantly, it'll keep it at a stable temp.
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #12April 30, 2006, 02:39:07 am
Baxter
« Reply #12 on: April 30, 2006, 02:39:07 am »
IMHO VW aren't stupid.
Those coolers/warmers are fitted to a hell of a lot of cars and have been for a good few years now. If they were that bad they wouldn't have used them for such a long time. This is ofcourse for stock applications.
If your pepping things up a little then fit an auxilliary oil cooler but keep the warmer too as said it reduces the difference in coolant and oil temperatures.
Just my thoughts, Simon.
Reply #13April 30, 2006, 09:42:32 am
« Reply #13 on: April 30, 2006, 09:42:32 am »
if you could find the thermostatically controlled oil cooler from an audi 5k TD, that would be perfect!!!
Reply #14April 30, 2006, 09:47:48 am
jackbombay
  • 599
« Reply #14 on: April 30, 2006, 09:47:48 am »
  Thoes have the same 100*C opening temp for the thermostat like the volvo unit, fwiw.
