Author Topic: Aligning the throttle lever.  (Read 2002 times)
April 24, 2006, 11:35:18 am
Baxter
« on: April 24, 2006, 11:35:18 am »
So, project going well, in the next week or so Im hoping to fit a different injection pump, but alas I have a problem.
The pump was supplied with no throttle lever, so there are no marks to align the lever with.
Is there a rule of thumb to set it up? From most of the others I have seen they are generally in the middle of the markings if that makes sense.
How much preload (If any) should there be on the capsule?
Correct me if im wrong but is all im trying to do is make the lever in the correct position for the cable to fit and the capsule just starting to make spring tension?
