VWDiesel Blog
Facebook Group
VWD on Twitter
Injection pump woes
Topic: Injection pump woes (Read 3164 times)
August 23, 2004, 03:43:10 am
CaddyTD
Newbie
Injection pump woes
August 23, 2004, 03:43:10 am »
I have successfully swapped the arrenoid (sp) from the TD pump to a known good N/A pump and was wondering if there are any adjustments that I need to make? What is the adjuster on the front of the pump for with a pinched collar? Do I need to adjust that at all? The reason I ask is that when you swap the tops, you swap that adjuster as well and the adjustment will not be correct.
Thanks!
Dave
1977 Rabbit 2dr Gas
1980 Dasher Diesel 2dr Ragtop
1980 VW Pickup Hot Rod
1980 Audi 5000S Diesel
1985 BMW 524td (Turbo Diesel)
I can FIX your broken speedo FOR GOOD!
My shop: VW Performance in Olympia, WA
"Stupidity should be painful"
August 26, 2004, 09:57:21 pm
Giles@PerformanceDiesel
Authorized Vendor
Why did u add the Anaroid?
August 26, 2004, 09:57:21 pm »
r u adding a turbo?
there are other changes inside the pump to make that u can't do
unless u take the pump apart.
Giles
August 27, 2004, 01:24:42 am
CaddyTD
Newbie
Injection pump woes
August 27, 2004, 01:24:42 am »
Yes. I am. I know you can use just the regular pump but wanted the extra fuel during higher boost and my turbo pump had problems.
Dave
1977 Rabbit 2dr Gas
August 27, 2004, 10:17:34 am
VWRacer
Injection pump woes
August 27, 2004, 10:17:34 am »
Wow...what a great link!
Stan
C-Sports Racer
August 27, 2004, 06:43:58 pm
dieselpower
Injection pump woes
August 27, 2004, 06:43:58 pm »
sorry this is a stupid question and a little off topic but.....how do you physically remove the top part of the injection pump. i tried but its conected to the linkages and i cant seem to find a way to disconect it.
thanks alot for your help
84 rabbit 1.6TD
because real cars don't have sparkplugs
August 28, 2004, 06:40:01 pm
dieselpower
Injection pump woes
August 28, 2004, 06:40:01 pm »
thanks...i got the pump apart last night. that post really helped me. should i get a new seal for it to put it back together? thanks again for the help.
84 rabbit 1.6TD
Injection pump woes
