Author Topic: p/n of IP advance/high idle lever plastic bushing  (Read 3434 times)
February 29, 2016, 06:46:18 am
92EcoDiesel Jetta
« on: February 29, 2016, 06:46:18 am »
I am swapping out the IP on my 92 Eco which is leaking at the main seal along with other issues (I have a spare 91 Eco motor with a good IP). The spare IP needs the plastic bushing (disintegrated) for the advance/high idle lever. The DGK 126 Bosch rebuild kit does not include this bushing. Anyone know the p/n and where to get it?
Reply #1February 29, 2016, 08:14:05 am
Re: p/n of IP advance/high idle lever plastic bushing
« Reply #1 on: February 29, 2016, 08:14:05 am »
Vag-cat (online ETKA) lists the part number.
Reply #2February 29, 2016, 08:45:26 am
92EcoDiesel Jetta
« Reply #2 on: February 29, 2016, 08:45:26 am »
Found this ETKA online http://etka.cc/vw but it does not work very well.
I know I entered my VIN correctly but I get[size=78%]:[/size]
Something is wrong…There is no result for your VIN code or your entered VIN code is incorrect! Please try again!
« Last Edit: February 29, 2016, 10:03:57 am by 92EcoDiesel Jetta »
Reply #3February 29, 2016, 11:57:42 am
  • 2926
« Reply #3 on: February 29, 2016, 11:57:42 am »
Dealership item.
They'll find it for you.
Kinda spendy.
 I have heard of someone cutting down some of the plastic plugs in the reseal kit and they fit.
Reply #4February 29, 2016, 03:19:16 pm
92EcoDiesel Jetta
« Reply #4 on: February 29, 2016, 03:19:16 pm »
Dealership item.
Kinda spendy.
Got p/n from dealer 068 130 337 , around $7 ea! Can someone verify this p/n for future reference even though I am not going to buy it since it's not in stock and I don't want to wait a few days. I went to plan B and made my own out of a piece of Nylon tubing. The new pump is installed, just have to connect the fuel lines and see if it'll start and fine tune the timing. I can post pics of how I made the bushing if anyone is interested.
Reply #5March 02, 2016, 07:30:13 am
92EcoDiesel Jetta
« Reply #5 on: March 02, 2016, 07:30:13 am »
Found a great thread of the bushing(s) with pic/ diagram / p/n http://www.vwdieselparts.com/forum/viewtopic.php?t=7889
Evidently 2 bushings are needed. Glad I didn't order from dealer because I would have paid $7 ordering one and then add insult to injury have to order another one!
Reply #6March 02, 2016, 11:27:40 am
  • 4549
« Reply #6 on: March 02, 2016, 11:27:40 am »
I went to the local hardware store and they have these nylon bushings in drawers that fit the lever just right and I only had to increase the diameter a very little bit to get the pin to go in place.  I think they cost about 40 cents.
Reply #7March 02, 2016, 02:31:10 pm
92EcoDiesel Jetta
« Reply #7 on: March 02, 2016, 02:31:10 pm »
My diy bushing is one piece. The nylon tubing I used was an interference for both o.d. and i.d. Had to use a heat gun to soften it to get it into bracket hole then a diamond grinding bit to increase the i.d. as shown here. Works fine and will never break again.
Reply #8March 02, 2016, 06:25:12 pm
  • 4549
« Reply #8 on: March 02, 2016, 06:25:12 pm »
Will = Way
