Author Topic: compression ratio? aaz 11mm pump holset turbo?  (Read 3990 times)
July 11, 2015, 05:33:06 am
mk3pete
  • 21
« on: July 11, 2015, 05:33:06 am »
ok so im building my aaz up from scratch! it was originally going to be a basic refresh but turns out my bores were flogged and had a bent rod.
il be running 1mm oversize nural pistons
roston h beams
Dieselmeken 11mm pump
holset he200wg
arp everything
ported head
hoping to make 30 to 35 psi
what would a recommended cr be? i know il be lowering from standard but how much lower?
Reply #1July 11, 2015, 07:41:24 am
Re: compression ratio? aaz 11mm pump holset turbo?
« Reply #1 on: July 11, 2015, 07:41:24 am »
You will be fine at the stock levels for aaz, I think that was around 22:1 for that engine. Cutting the dish out in the piston, porting the prechamber, or undercut valves are the only way I would take compression down.
Reply #2July 11, 2015, 11:47:18 am
« Reply #2 on: July 11, 2015, 11:47:18 am »
That build will not last long unless you have a crank girdle.  Otherwise you will break a main.
Reply #3July 11, 2015, 02:36:48 pm
« Reply #3 on: July 11, 2015, 02:36:48 pm »
I wonder what it is about the AAZ blocks that seems to make them so much more prone to breaking mains. Seen more than a few now. The TDI blocks don't seem to have as much of an issue despite being virtually the same.
Reply #4July 11, 2015, 09:15:13 pm
« Reply #4 on: July 11, 2015, 09:15:13 pm »
65mm main bolts came in some aaz, the others had 80mm like the tdi. I would guess that is a part of it.
Reply #5July 11, 2015, 10:39:34 pm
mk3pete
  • 21
« Reply #5 on: July 11, 2015, 10:39:34 pm »
I was thinking about a girdle but wasnt sure if I need longer bolts to torque it down? If so anyone know where to order. Or any other requirements I need to run one.
Roston do a girdle and that's where im buying most of my parts.
Might have to throw him an email.
Reply #6July 11, 2015, 11:06:15 pm
mk3pete
  • 21
« Reply #6 on: July 11, 2015, 11:06:15 pm »
Maybe someone might be kind enough to release a drawing of one so I can machine it up myself?
Dads got a milling machine at home so il get some 6 mm plate! Bright steel would be best as theres no mill scale on it to worry about cleaning up.
« Last Edit: July 12, 2015, 04:15:39 am by mk3pete »
Reply #7July 12, 2015, 07:24:00 am
Gizmoman
  • 1301
« Reply #7 on: July 12, 2015, 07:24:00 am »
Sandblasting will remove scale as well  ; - )
Not sure what you goals are but make sure the rest of the vehicle is up to the increase if your goal is reliability.
Reply #8July 12, 2015, 02:57:16 pm
mk3pete
  • 21
« Reply #8 on: July 12, 2015, 02:57:16 pm »
Im already running o2a and bigger clutch also g60 brakes, I have another built box on my vr6 im thinking about swapping into the td 3.94 rp peloquin and tdi 5th.
