Author Topic: help identifying a very unhealthy sound  (Read 16104 times)
May 20, 2015, 07:54:13 pm
« on: May 20, 2015, 07:54:13 pm »
Got my aaz rabbit back on the road last night and after about 20 minutes of driving it began making this noise, it goes away under mostly acceleration and depressing the utch changes it some.  It seems to be louder on the trans side of the car.  I turned over the engine by hand and it felt fine, it also still drives the same and has no loss of power, thanks for any help!
Reply #1May 20, 2015, 09:45:50 pm
Re: help identifying a very unhealthy sound
« Reply #1 on: May 20, 2015, 09:45:50 pm »
Wow, that sounds terrible.  Turbo would be my first guess, but odd that you aren't feeling a loss of power.
How's the alt?  Clutch?
Reply #2May 21, 2015, 04:35:09 am
« Reply #2 on: May 21, 2015, 04:35:09 am »
i would say it is definitely not the turbo it boosts fine to 12psi and sounds normal, i also felt it by hand feels just like new(i just rebuilt it.)  maybe some of the sound quality was lost when i uploaded the video.  it sounds like more of a rattling knocking sound, almost like it could be a precup coming loose hitting the piston, but i would think i'd have a loss of power for that, also a more consistent sound.  alternator is fine, but i am suspicious of the clutch setup, it drives fine but something may have come loose with it, i think i can get a 1/4" ratchet in to the timing hole and make sure the flywheel bolts are tight.
also for years even before this swap, the starter on this car would have the bendix stick out for a second or 2 after starting, so it could be related to that although it starts fine.(with lots of noise)  i'll also be pulling the starter tonight.
« Last Edit: May 21, 2015, 04:48:10 am by RabbitJockey »
Reply #3May 21, 2015, 07:39:38 am
« Reply #3 on: May 21, 2015, 07:39:38 am »
Does the sound change if you remove the green alligator clip?
Have you tested your lifters?
Reply #4May 21, 2015, 08:31:08 am
jmaddocks
  • 75
« Reply #4 on: May 21, 2015, 08:31:08 am »
My son's Jetta started making a horrible racket several weeks ago.  Pressing the clutch would change the sound.  Turns out we had ripped two of the straps on the pressure plate...one was still dangling from the PP, and the other was just bouncing around inside the bell housing.  Just another idea, fwiw.
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #5May 21, 2015, 09:23:46 am
« Reply #5 on: May 21, 2015, 09:23:46 am »
Ill check that stuff tonight.
Reply #6May 21, 2015, 02:14:51 pm
« Reply #6 on: May 21, 2015, 02:14:51 pm »
Pressure plate to crank bolts must have backed out, i can reach in and there is about Half an inch of play that i move the pp/flywheel by hand.  Hopefully the pp holes have elongated so i dont have to buy a new pp.  I guess well see once i get it torn off.  I am certain that i torqued the crank bolts properly but i must have done something wrong.  Either way, atleast the engine is ok, this could have been a much worse situation
Reply #7May 22, 2015, 07:21:30 am
« Reply #7 on: May 22, 2015, 07:21:30 am »
you guys can make fun of me, it's ok i can handle it
Reply #8May 22, 2015, 08:05:41 am
jmaddocks
  • 75
« Reply #8 on: May 22, 2015, 08:05:41 am »
As a guy who gave up a good chunk of a weekend on my back two weeks ago, changing a nine-month-old clutch (between business trips, no less), I'm in no position to make fun of you...   ;D
I'm just glad you found out what's making the noise.  Curious about root cause, once you're able to do some forensics.
Reply #9May 22, 2015, 09:49:32 am
« Reply #9 on: May 22, 2015, 09:49:32 am »
haha, it's all a part of the journey and learning not to *** up.  i know i torque the bolts proper but i am not sure whether or not i did the final quarter turns.  i am just hoping that the pressure plate holes are still round, how ever i doubt that they are, and i am thinking i will have to buy a new one.  and i had used new bolts that even come with loctite already on them... clearly something when wrong though.
« Last Edit: May 22, 2015, 12:25:28 pm by RabbitJockey »
Reply #10May 23, 2015, 05:30:27 am
Gizmoman
  • 1301
« Reply #10 on: May 23, 2015, 05:30:27 am »
No expert here but when you install the new bolts, make sure you run a bottoming tap into the holes first and blast em good with brake cleaner and air a few times.
Reply #11May 23, 2015, 11:34:26 am
air-cooled or diesel
« Reply #11 on: May 23, 2015, 11:34:26 am »
when i first heard it, the quality isnt too good, you can hear some clicking, but the main sound is like something has spun, a whirring; yup a clutch plate coming loose prob sounds like that; hopefully you can fix it and no big problem.
Reply #12May 27, 2015, 11:02:09 am
dontdoemyourself
  • 110
    • www.clearviewmt.com
« Reply #12 on: May 27, 2015, 11:02:09 am »
This happened to a worked 2.0 16v I had years ago.. Didn't figured it out until I was replacing the bottom end of the engine again and my PP wouldn't come off.. D'oh!
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #13May 28, 2015, 05:18:40 am
« Reply #13 on: May 28, 2015, 05:18:40 am »
your pp was stuck on?
Reply #14May 28, 2015, 09:36:32 pm
dontdoemyourself
  • 110
« Reply #14 on: May 28, 2015, 09:36:32 pm »
Yeah, it chewed up the crank end, and required some prying to get it off.. I had just replaced the bottom end due to a spun bearing a few weeks before, and figured it was that again.. After I found the loose pressure plate it made sense,
