Author Topic: Anyone here running an he221w with an n/a pump?  (Read 6595 times)
April 05, 2015, 03:13:09 pm
Smoker
  • 255
« on: April 05, 2015, 03:13:09 pm »
Just that. I need some more excitement in my life.
Reply #1April 06, 2015, 06:13:40 am
jmaddocks
  • 75
Re: Anyone here running an he221w with an n/a pump?
« Reply #1 on: April 06, 2015, 06:13:40 am »
I'm running an he200wg with a modded n/a pump (altitude-compensating lda with the ports reversed).
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #2April 06, 2015, 06:24:26 am
Smoker
  • 255
« Reply #2 on: April 06, 2015, 06:24:26 am »
How is it? Do you have a rough idea of power output? Do you have a build thread somewhere?
Reply #3April 07, 2015, 06:56:04 am
jmaddocks
  • 75
« Reply #3 on: April 07, 2015, 06:56:04 am »
No idea what the power output is, but I'm guessing it's somewhere around 150 whp.  The car will give a new WRX a run for its money, while still averaging 45-47 mpg in city driving (this is with a 17-year-old driving it!).  It's a pretty revvy setup that pulls hard to redline but still has the torque to break loose halfway through second on dry pavement.  Very happy with the setup so far.  I can pm you the details if you'd like.
Reply #4April 07, 2015, 06:57:33 am
Smoker
  • 255
« Reply #4 on: April 07, 2015, 06:57:33 am »
Please do!
Reply #5April 12, 2015, 09:15:09 pm
ToddA1
  • 434
« Reply #5 on: April 12, 2015, 09:15:09 pm »
No internal mods to the pump... just swapped ports?
-Todd
Reply #6April 19, 2015, 06:00:53 pm
jmaddocks
  • 75
« Reply #6 on: April 19, 2015, 06:00:53 pm »
-Todd
Sorry I missed this.  Governor mod, fuel turned up, and star wheel adjusted to increase preload on the LDA spring.  We still get quite a bit of smoke during boost transients, so I'm sure it needs a stiffer LDA spring.  Also, believe it or not, we're not limited by fueling at full boost but live at altitude.
Smoker - you had asked about my clutch setup in a pm, and I mentioned I was running a 16v pressure plate and 8v disc (with 210mm lightened flywheel).  We recently had a near-catastrophic clutch failure and were lucky to get home.  Two out of three straps on the PP failed, doing a number to the inside of our bell housing and creating a horrible racket whenever the clutch was disengaged.  Based on a bit of web research, it is not an uncommon failure mode.  Needless to say, I do not recommend running a Sachs 16v PP with a Holset at high boost.
I'm upgrading to an ACT setup.  Just wanted to let you know before you started buying everything and to document this for other folks doing research.
Reply #7April 19, 2015, 07:20:50 pm
« Reply #7 on: April 19, 2015, 07:20:50 pm »
ive heard lots of bad things about performance and the new sachs pp's.  i went with a clutchnet setup for my build, never heard anything bad about them.
Reply #8April 20, 2015, 05:59:37 am
jmaddocks
  • 75
« Reply #8 on: April 20, 2015, 05:59:37 am »
Good choice.  It came down to clutchnet or ACT for me...I could've gone either way.
Reply #9April 20, 2015, 09:51:10 am
« Reply #9 on: April 20, 2015, 09:51:10 am »
did you install it?  how much did it cost?  i got the yellow kit for an 84 gti, then had a flywheel lightened and cut which cost 150.  the clutch kit was 309 so i ended up with about 460 in to it, and its a lot of clutch, definitely won't be slipping.  the pp is really strong i wish i had gotten a weaker one with a 6 puck disc instead because the pedal is very heavy and my engine isn't that heavily modified for me to be bothered with the heavy pedal.
Reply #10April 20, 2015, 09:52:10 am
« Reply #10 on: April 20, 2015, 09:52:10 am »
but i see yours is in a mk2 which has a nicer longer pedal that seems easier to push, mine is a mk1.  i only have 20 miles on it though
Reply #11April 20, 2015, 09:59:47 am
Smoker
  • 255
« Reply #11 on: April 20, 2015, 09:59:47 am »
Those prices seem very reasonable. I guess I'm still used to looking at upgraded clutches for my old stage 2.5 2.7t!
Reply #12April 20, 2015, 11:43:33 am
jmaddocks
  • 75
« Reply #12 on: April 20, 2015, 11:43:33 am »
Since I wasn't having problems with slippage per se, and just needed a pressure plate with more robust construction, I simply bought an ACT pressure plate to use with the Sachs disc I just installed last August.  During my research, I found two other folks who went the same route and had no subsequent problems.  For my intended usage (street only), I think this setup will be fine.
Here's a link to the pp on amazon...$222 shipped:  http://www.amazon.com/gp/product/B000CIK4II/ref=od_aui_detailpages00?ie=UTF8&psc=1
I got all the other stuff (e.g., stretch bolts and thrust plate) from GAP.
hth
Reply #13April 20, 2015, 11:54:22 am
« Reply #13 on: April 20, 2015, 11:54:22 am »
hmm ok, i just reused my thrust plate it only had around 30k on it, and used the old reusable fw bolts on mine, the hex head ones are reusable.
Reply #14April 20, 2015, 01:26:08 pm
jmaddocks
  • 75
« Reply #14 on: April 20, 2015, 01:26:08 pm »
Yeah, I'm just replacing the hex bolts.  The 12 pt flywheel bolts are not stretch bolts and can be reused (and I just replaced them in August...).
I'm replacing the thrust plate because the wear point moved a bit off center after the pp straps broke.  I've seen a lot of instances in which folks have had the pushrod punch a hole through the middle of it -- didn't want to take any chances.
