AAZ Pump Differences?
Pages:
Topic: AAZ Pump Differences? (Read 9192 times)
Reply #15
March 30, 2015, 08:35:07 pm
RunninWild
Re: AAZ Pump Differences?
Reply #15 on:
March 30, 2015, 08:35:07 pm »
Thanks burn, you've been a great help! If I cant get a bracket off the PO do you know if one from a 1.6(t) would work?
Reply #16
March 30, 2015, 08:48:16 pm
Reply #16 on:
March 30, 2015, 08:48:16 pm »
All 1.6s are 50mm. I might be able to grab one for you at the yard next time I'm there (about a month). Pulley too if you need it. Send me a PM in 2-3 weeks if you are still looking.
Reply #17
April 01, 2015, 07:43:41 pm
RunninWild
Reply #17 on:
April 01, 2015, 07:43:41 pm »
any idea if the ALH pump sprocket would work?
http://www.ebay.com/itm/Injection-Pump-Pulley-Gear-VW-Jetta-Golf-MK4-Beetle-ALH-1-9-TDI-038-130-111-A-/311321949618?hash=item487c3bf5b2&vxp=mtr
Looks the same in pics...
Reply #18
April 01, 2015, 08:42:14 pm
Reply #18 on:
April 01, 2015, 08:42:14 pm »
I know it will bolt to your pump but I don't know if the offset is correct.
Reply #19
May 15, 2015, 07:12:19 am
dontdoemyourself
Reply #19 on:
May 15, 2015, 07:12:19 am »
I am now in need of some advice in this department... I bought runninwild's LDA pump for a Giles rebuild but will need to swap over to the later 68mm style bracket (I have an alh on the way, hoping it will work!) as well as a sprocket.. Is there any other mechanical parts I'll need??
1982 Vanagon diesel mTDi
1982 Jetta coupe - AHU/O2A project
1977 Scirocco Champagne 1.8 RV / Digi2
1963 Microbus Panel camper
05 Audi Allroad 6spd
01 Toyota Tundra V6 5VZFE/ 5 speed
Reply #20
May 15, 2015, 07:30:06 am
Reply #20 on:
May 15, 2015, 07:30:06 am »
You are trying to use an ALH accessory/pump bracket on an AAZ? That won't work.
Reply #21
May 15, 2015, 07:33:38 am
RunninWild
Reply #21 on:
May 15, 2015, 07:33:38 am »
Other then the lda, bracket and the sprocket both pumps looked identical. I don't think anything different would be needed for you to run it. Did you get those links I sent you to those ebay auctions with the proper brackets?
Reply #22
May 15, 2015, 10:41:39 am
Reply #22 on:
May 15, 2015, 10:41:39 am »
The ALH engine block is very very different. The mounting points for the bracket to the engine are not the same. You can't bolt an ALH bracket to an AAZ block.
Reply #23
May 15, 2015, 08:24:59 pm
dontdoemyourself
Reply #23 on:
May 15, 2015, 08:24:59 pm »
Shoot.. Are the ahu ones that are interchangeable? Ok.. Guess I need an AAZ bracket .. And pulley.. Anyone have a line?
Reply #24
May 15, 2015, 08:30:17 pm
Reply #24 on:
May 15, 2015, 08:30:17 pm »
The only bracket that will fit the larger snout AAZ pump is the stock bracket that came with that pump. The center hole of the AHU bracket fits the smaller snout pump so it will not work without machining to the larger diameter.
Reply #25
May 15, 2015, 11:19:30 pm
RunninWild
Reply #25 on:
May 15, 2015, 11:19:30 pm »
http://m.ebay.com/itm/231529515752?nav=SEARCH
http://m.ebay.com/itm/131494032247?nav=SEARCH
First one is obo so you can low ball and might get lucky.
Reply #26
May 16, 2015, 07:13:58 am
Reply #26 on:
May 16, 2015, 07:13:58 am »
The first link is the wrong bracket. It fits the smaller snout. The second looks right.
Reply #27
May 16, 2015, 08:08:52 am
dontdoemyourself
Reply #27 on:
May 16, 2015, 08:08:52 am »
Cool, I actually bought my bracket from the guy who posted the second link.. So am I correct in my observation that there is no pump lock on the late AAZ bracket...??
Reply #28
May 16, 2015, 10:56:05 am
Reply #28 on:
May 16, 2015, 10:56:05 am »
The hub/sprocket style pump has a pin that slides between the hub and the pump case so there is no interaction between the pin and the bracket.
Reply #29
May 17, 2015, 09:21:38 pm
dontdoemyourself
Reply #29 on:
May 17, 2015, 09:21:38 pm »
Nice, now to find a sprocket.. Will the tdi ones work? Is there any other electrical connections I'll need to hook up?
Pages:
