Author Topic: Injectors  (Read 4442 times)
October 17, 2014, 09:32:38 am
rodpaslow
  • 670
Injectors
« on: October 17, 2014, 09:32:38 am »
Can't seem to find this in search - can you swap alh injectors into a older 1Z/AHU engine?  I know they have different break pressures.  Is that any problem for a M-tdi pump? (LR)
Reply #1October 17, 2014, 01:57:51 pm
Re: Injectors
« Reply #1 on: October 17, 2014, 01:57:51 pm »
Pretty sure the AHU injectors actually have the same pop pressure as the ALH actually. The 1Z was initially different though I believe, however I think that may have been changed mid life cycle.
Either way, no harm whatsoever swapping in ALH parts, especially with a mechanical pump. Timing is the only thing that would be affected.
Reply #2October 17, 2014, 03:15:47 pm
Re: Injectors
« Reply #2 on: October 17, 2014, 03:15:47 pm »
ALH injectors are interchangeable with AHU but I keep them as sets.
Reply #3October 21, 2014, 08:52:41 am
rodpaslow
  • 670
Re: Injectors
« Reply #3 on: October 21, 2014, 08:52:41 am »
Yeah, I just wanted a spare set as I think it would be much easier to just swap out new (new nozzles) with old, and possibly experiment with different sizes to find what works best with setup.
