Author Topic: Aaz timing belt sliding on pulley  (Read 3363 times)
August 11, 2014, 05:19:45 pm
boomenstein
  • 35
« on: August 11, 2014, 05:19:45 pm »
Hey guys, hope maybe some of you experts can help me?
I swapped a aaz into my s1 scirocco and it's running all good but I noticed that the belt has drifted on the pump pulley to one side, see pic
Now the belt started off flush with one side of the pulleys, u can see in this pic how the cam pulley is flush, this is how the pump pulley used to look.
Any thoughts??
Reply #1August 12, 2014, 06:03:07 am
Gizmoman
  • 1301
Re: Aaz timing belt sliding on pulley
« Reply #1 on: August 12, 2014, 06:03:07 am »
I was hoping someone with more knowledge than I would respond - anyway. . .
I believe there is a bit of movement between the IP mount bracket holes and the bolts. If you loosen them a bit and tap with a dead-blow, you should get it to align.
Make sure it's not overtightened!
Reply #2August 12, 2014, 07:22:43 am
« Reply #2 on: August 12, 2014, 07:22:43 am »
To get it to track further from the engine, you need to pull the pump, loosen the three allen bolts behind the injection pump and rotate the sprocket side of the bracket UP and the injection lines side DOWN.  Then reinstall pump and check tracking.  It can take a few tries to get it dialed in correctly.
Reply #3August 12, 2014, 03:49:21 pm
boomenstein
  • 35
« Reply #3 on: August 12, 2014, 03:49:21 pm »
Thanks for the replies guys, I am using a 1.6 motor/injection pump bracket, would this play a part in this?
Reply #4August 12, 2014, 05:31:43 pm
Gizmoman
  • 1301
« Reply #4 on: August 12, 2014, 05:31:43 pm »
Size of pump has nothing to do with it that I'm aware of.
Pretty much what libby said.
Typically, these belts are made in molds under very tight restrictions. Having it track differently than the one you took off would have me checking things very carefully. If you've had the pump off or may have smacked it somehow that would explain the issue but it can be remedied by the above adjustment.
Reply #5August 12, 2014, 06:42:17 pm
« Reply #5 on: August 12, 2014, 06:42:17 pm »
The situation/solution is the same, but the number of bolts to loosen and tighten to adjust is different.  Sometimes you can get away with just moving the part of the bracket that is behind the pump.  Sometimes you need to loosen the plate along the end of the block and move that in the opposite direction.
Reply #6August 13, 2014, 10:18:03 am
boomenstein
  • 35
« Reply #6 on: August 13, 2014, 10:18:03 am »
Thanks again guys!
I did have the pump off to change the mount, I will try the alignment, hopefully I don't have to remove the pump again.
Does anyone have any suggestions where to get those caps to put over the 4 fuel outlets on the pump if I do have to remove it?
Reply #7August 13, 2014, 12:44:48 pm
« Reply #7 on: August 13, 2014, 12:44:48 pm »
...use heavy duty aluminum foil.
Reply #8August 13, 2014, 01:35:57 pm
« Reply #8 on: August 13, 2014, 01:35:57 pm »
Thanks again guys!
Are they just "vacuum line caps" you can get at an auto parts store? My local hardware store also had a drawer full of those little plastic caps of various sizes. They were labeled as "bolt covers" or something like that.
