Author Topic: Crankshaft pulley bolt size  (Read 4130 times)
March 24, 2014, 06:57:44 am
icyhotpatch
  • 117
« on: March 24, 2014, 06:57:44 am »
Anyone know? Someone moved my stuff and now I can't find it. I'm sure I will when I'm done putting things back together.
Most likely wasting time while at work.
Reply #1March 24, 2014, 06:58:57 am
Re: Crankshaft pulley bolt size
« Reply #1 on: March 24, 2014, 06:58:57 am »
The big one or the 4 smaller ones?
Reply #2March 24, 2014, 06:59:41 am
icyhotpatch
  • 117
Re:
« Reply #2 on: March 24, 2014, 06:59:41 am »
The big one. 1.6l out of an 82.
Reply #3March 24, 2014, 07:00:59 am
« Reply #3 on: March 24, 2014, 07:00:59 am »
I don't know the answer off hand but if it was 12pt it is a one time use bolt. 6 point can be reused.
Reply #4March 24, 2014, 07:01:58 am
icyhotpatch
  • 117
Re:
« Reply #4 on: March 24, 2014, 07:01:58 am »
I believe it was a 6pt any place I could look it up?
Reply #5March 24, 2014, 07:55:29 am
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #5 on: March 24, 2014, 07:55:29 am »
M12 by something i think?
I just took one out yesterday. this means that there is little chance i can find it.
Reply #6March 24, 2014, 08:22:33 am
icyhotpatch
  • 117
Re:
« Reply #6 on: March 24, 2014, 08:22:33 am »
That's how I feel. Its the same thread as the camshaft and intermediate shaft isn't it?
Reply #7March 24, 2014, 08:43:20 am
« Reply #7 on: March 24, 2014, 08:43:20 am »
Somewhere there is the old crank, but I think that was the 1.5, and it had a smaller bolt IIRC. The newer 12 point bolt can be used *1 time* in place of the 6 point bolt you used to have. It is available just look for 97 AHU TDI crank sprocket bolt and follow the bolt's torque procedure.
Reply #8March 24, 2014, 08:56:34 am
TimpanogosSlim
  • 590
« Reply #8 on: March 24, 2014, 08:56:34 am »
huh. The 6 point i took out has some slightly rounded corners but i don't know that i want to replace it with a 12 point that can't be reused.
Reply #9March 24, 2014, 09:08:18 am
« Reply #9 on: March 24, 2014, 09:08:18 am »
Despite the newer bolt not being reusable, it does its job very well and is quite cheap.  The engineers moved to TTY bolts because they provide a more consistent clamping force.  The bolt itself when properly installed and not reused generally does not fail.
Reply #10March 24, 2014, 09:48:54 am
« Reply #10 on: March 24, 2014, 09:48:54 am »
The 12pt I have here is M14 x 47 x 1.5
Reply #11March 24, 2014, 10:06:55 am
icyhotpatch
  • 117
Re:
« Reply #11 on: March 24, 2014, 10:06:55 am »
OK thanks. I like this forum.
