Author Topic: Engine lifting hooks and egt probe questions  (Read 3191 times)
February 16, 2014, 07:16:07 am
Spokerider
  • 195
« on: February 16, 2014, 07:16:07 am »
1993 AAZ......into an 87 Samurai
Since I got my engine as a short block and pieces, with many missing pieces, I'm not sure where the lifting hooks go [for attaching the cherry picker chain / bar] or even what they look like?
 Also, wanting to drill a 1/8th NPT hole in the exhaust manifold for a future egt probe. Where should it go.......in the stud-hole? Just before the stud hole on the nickel sizes flat spot on the manifold?
I've seen a few pics of both installations. What is that exhaust bracket [ that bolts onto the two studs near the exhaust flange ] for anyway? I'm not sure if I will need that bracket for my sami swap or not. I will have a custom exhaust pipe from the exhaust manifold flange to tail pipe.
I have the K03 turbo with the 3 bolt / triangular shaped flange on the exhaust manifold.
Thanks for your help.
Reply #1February 16, 2014, 07:24:15 am
bbob203
  • 1789
Re: Engine lifting hooks and egt probe questions
« Reply #1 on: February 16, 2014, 07:24:15 am »
one hole is on the transmission end of the head the other one bolts to the front of the head by the #1 injector.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2February 17, 2014, 05:32:02 am
Spokerider
  • 195
« Reply #2 on: February 17, 2014, 05:32:02 am »
Thanks for the info bob.
Reply #3February 17, 2014, 06:18:55 am
« Reply #3 on: February 17, 2014, 06:18:55 am »
On the 1.6, the right side has a short tab that attaches at the same boss as the upper alternator bracket. The other end of the head has a cast flange with a hole (near the corner of the valve cover).
Reply #4February 17, 2014, 06:46:18 am
homerj1
  • 433
« Reply #4 on: February 17, 2014, 06:46:18 am »
Here is where I installed my egt probe in my 1.6td with a k03 combo
http://www.vwdiesel.net/forum/index.php?topic=32936.0
I hope this helps?
Aivars
