Author Topic: FN trans clutch size  (Read 3573 times)
February 15, 2014, 07:53:05 pm
Blue Haze
  • 49
    82 caddy w/AAZ 1.9 motor 5spd w/ A/C
« on: February 15, 2014, 07:53:05 pm »
What is the largest diameter clutch ,PP and flywheel that will fit in a FN 5 spd trans?
Reply #1February 15, 2014, 09:58:22 pm
Re: FN trans clutch size
« Reply #1 on: February 15, 2014, 09:58:22 pm »
The largest I know of is the 210mm setup. Maybe someone else knows of something other than that?
Reply #2February 17, 2014, 12:19:31 pm
Blue Haze
  • 49
« Reply #2 on: February 17, 2014, 12:19:31 pm »
Thanks, when I put my AAZ mtr in the installer said that the 210 I bought from Clutch net would not fit I did not think that was right but I had to go with it so I have a 200 in there and an expensive 210 sitting on the shelf.  You live and learn!!
Reply #3February 17, 2014, 02:36:35 pm
dieseljunkie69
  • 47
    81 Jetta
« Reply #3 on: February 17, 2014, 02:36:35 pm »
The AAZ would have been 210mm stock. So either your clutchnet clutch needed a different flywheel/pp combo than stock? Or he was a moron that doesn't know snakes from ladders..
How is the 200mm? Stock?? Is it slipping?
I'm That Guy.
Reply #4February 17, 2014, 03:36:55 pm
« Reply #4 on: February 17, 2014, 03:36:55 pm »
There was a large *IIRC* 26 spline for the 020 and the smaller 24 spline for the earlier 020. Tthe outsides were the same it was the splined shaft in the center he could have been talking about.
Reply #5February 17, 2014, 05:28:49 pm
dieseljunkie69
  • 47
    81 Jetta
« Reply #5 on: February 17, 2014, 05:28:49 pm »
I do believe the only way that could happen is if the OP bought a clutch disk for a 16v motor.. I am certain all production line 8v 020's were the smaller clutch spline. Even the mk3 1.9 AAZ 020's.
I'm That Guy.
Reply #6February 17, 2014, 09:50:06 pm
Blue Haze
  • 49
« Reply #6 on: February 17, 2014, 09:50:06 pm »
I believe it is the smaller spline the diameter I was told was why it would not fit. The 200 is holding up just fine.  I was told that it is a hvy duty 200 if that is possible. I turned up the fueling today according to the post "how to    make your IDI faster"  and still held just fine.
Reply #7February 18, 2014, 05:05:52 am
« Reply #7 on: February 18, 2014, 05:05:52 am »
Your FN for sure will have the smaller splines, but if you got the clutch from him it is a possibility that his car had the larger spline trans. I don't know what the aaz got, but I know some mkiii got the big spline clutch. This is from broke vw...CHE,DFQ,DGD,AMC 3.45 1.94 1.28 0.97 0.80 3.67 From '93 115hp,Large input shaft
It should hold you for a while. Just make sure to get the small spline 210mm if you need another.
