Author Topic: Intermittent missing  (Read 14387 times)
Reply #30January 27, 2014, 12:14:51 pm
Re: Intermittent missing
« Reply #30 on: January 27, 2014, 12:14:51 pm »
A combustion leak to coolant corrodes everything in the cooling system, including the oil cooler....which you can pressure test failrly easily.
Reply #31January 27, 2014, 05:43:24 pm
Gizmoman
  • 1301
« Reply #31 on: January 27, 2014, 05:43:24 pm »
I'm thinking sloppy weld repair of  previous foreign object damage, harder to see because the high spots have been milled.
X2 /\
I agree 100% with the above. Also, what appears to be a crack may actually be a cut from a not-so-good mill job.
Reply #32January 30, 2014, 04:25:13 pm
brownni
  • 21
« Reply #32 on: January 30, 2014, 04:25:13 pm »
Well fellas, I pulled it all apart and here are some initial photos.
Here is the head after wiping all the wet oil off the surface, but prior to any other cleaning:
http://sdrv.ms/1bbnSnH
Here it is after just scraping off the carbon deposits with a razor blade:
http://sdrv.ms/1bbnXHY
The crack that was circled in red in the earlier pictures of this post is here:
http://sdrv.ms/1bbob1J
http://sdrv.ms/1bbojOV
When I look into that coolant passage, you can see the crack line for a good 2mm up into that passage. Maybe that was my problem. There are also plenty of other little cracks along machine marks that look like they could cause issues for me too, but this seems like the most leaky crack since it isn't along a machine mark.
Also - sorry that these are just links. I am not clever enough to figure out how to get direct links to the image files so that the forum can display them embedded in the post.
Reply #33January 30, 2014, 04:59:44 pm
Gizmoman
  • 1301
« Reply #33 on: January 30, 2014, 04:59:44 pm »
So what's your plan, a new or rebuild head?
I ran across this. . .
http://inlandempire.craigslist.org/ptd/4289213684.html
« Last Edit: January 30, 2014, 05:03:41 pm by Gizmoman »
Reply #34January 30, 2014, 05:27:21 pm
« Reply #34 on: January 30, 2014, 05:27:21 pm »
Nice pix... it can really be seen how #4 is really an outlier.
The cause of the damage may be moot... bustid is bustid.
Reply #35January 30, 2014, 06:26:37 pm
Mark(The Miser)UK
  • 1557
« Reply #35 on: January 30, 2014, 06:26:37 pm »
I'd be inclined to fill that crack somehow, as it's so fine, and should be easy to 'clog up', solder,weld etc. The head looks pretty flat  otherwise....
Mark-The-Miser-UK
Reply #36January 31, 2014, 01:45:30 am
« Reply #36 on: January 31, 2014, 01:45:30 am »
VS. heat expansion and peak  combustion pressure, I think not.  You can get it welded it up but it will cost more than a new head.
Is that another  from 1:00 on #4 intake to the bottom of the prechamber?
Reply #37January 31, 2014, 02:12:26 am
« Reply #37 on: January 31, 2014, 02:12:26 am »
...Is that another  from 1:00 on #4 intake to the bottom of the prechamber?
If it is, that's much closer to the main oil passage that runs along the head. Still quite a way tho.
« Last Edit: January 31, 2014, 02:28:19 am by TylerDurden »
Reply #38January 31, 2014, 09:09:06 am
Mark(The Miser)UK
  • 1557
« Reply #38 on: January 31, 2014, 09:09:06 am »
Anyone ever used Al MIG?
Mark-The-Miser-UK
Reply #39January 31, 2014, 11:58:53 am
Toby
  • 728
« Reply #39 on: January 31, 2014, 11:58:53 am »
Yes and it would be a bad idea for repairing cracks. High deposition and low pen.
Reply #40January 31, 2014, 04:36:45 pm
Mark(The Miser)UK
  • 1557
« Reply #40 on: January 31, 2014, 04:36:45 pm »
H'mm I bought a coil of it for my MIG and never got round to using it. Wasn't there a reverse polarity issue? Hard to believe a little non structural crack can't be filled. Wattle and Daub probably do it
Mark-The-Miser-UK
Reply #41January 31, 2014, 07:48:44 pm
« Reply #41 on: January 31, 2014, 07:48:44 pm »
easy as
http://forums.tdiclub.com/showthread.php?t=175661
but unless you have a rare or special head, why?
Reply #42January 31, 2014, 09:19:40 pm
brownni
  • 21
« Reply #42 on: January 31, 2014, 09:19:40 pm »
What kind of tooling does one use to hold a head in place on a milling machine? It isn't as simple as just clamping it in a vice is it? What surface do you square up to when you have a semi-warped head, or a welded face?
Reply #43January 31, 2014, 10:39:12 pm
Dakotakid
  • 1240
« Reply #43 on: January 31, 2014, 10:39:12 pm »
Brown, dude.....get your hands on a viable cylinder head....stop listening to the usual mindless dribble, and get on with your life.
Clearly the old head had the crap traumatized out of it. Box it up and ship it overseas.
Thank you.
Reply #44February 01, 2014, 02:21:07 am
Mark(The Miser)UK
  • 1557
« Reply #44 on: February 01, 2014, 02:21:07 am »
Sand paper and 3 sheets of plate glass will do it on the kitchen table. This will machine the inconel as well.
Stick it on a banana boat to me and it will live again.  ;D
Even silicone pressed in with a dinner knife would seal that crack
Mark-The-Miser-UK
