Author Topic: A few more aaz crank questions  (Read 1975 times)
January 16, 2014, 08:15:35 am
Spokerider
  • 195
« on: January 16, 2014, 08:15:35 am »
I have the crank out of the aaz block.......taking to a machinist for nose repair.
 When I go to install, is there something better than just motor oil to lube the journals and cap bearings with?, considering that this engine is a fresh rebuild and has zero run time.
Also, the new crank sprocket bolt, apply motor oil or red Loctite? or? I read that VW uses *something* other than oil now.....a thread locking compound of some sort?
Thanks.
Reply #1January 16, 2014, 10:57:42 am
Dakotakid
  • 1240
Re: A few more aaz crank questions
« Reply #1 on: January 16, 2014, 10:57:42 am »
You've never heard of "assembly lube?" Well, then.....assembly lube.
Reply #2January 16, 2014, 02:30:12 pm
Spokerider
  • 195
« Reply #2 on: January 16, 2014, 02:30:12 pm »
Thanks, just bought some.
Last engine I rebuilt was 1981  ;D
