Author Topic: AAZ Injector Lines - let em relax!  (Read 12629 times)
January 15, 2014, 06:25:30 pm
Gizmoman
  • 1301
« on: January 15, 2014, 06:25:30 pm »
I've been taking my van to work every morning to get the "bugs" worked out after the refurbish.
It's a 40+ mile round trip with some good freeway grades, and high speed traffic so it's a good test.
I adjusted the IP timing last weekend and forgot to loosen up each nut and let the lines "relax" to their new position.
Well, #2 line cracked this morning just before I arrived so I need a new line. I think I'd like to replace the entire set as they have all been stressed and I don't want to worry about them in the future.
I found a set on e-bay http://www.ebay.com/itm/VW-Volkswagen-1-9D-1-9TD-Diesel-1Y-AAZ-Fuel-Injector-Pressure-line-kit-/171098306000
$170 + but would like opinions from other or possibly more reliable sources.
Till I get them, the van is parked at work locked up tight. Prompt responses appreciated!
Engine is a 1.9 AAZ
*EDIT* Will AHU (or other styles) work? I found some for 70 bucks on ebay as well (I already know TDI won't fit).
« Last Edit: January 15, 2014, 06:39:27 pm by Gizmoman »
Reply #1January 15, 2014, 07:15:40 pm
410
  • 581
Re: AAZ Injector Lines - let em relax!
« Reply #1 on: January 15, 2014, 07:15:40 pm »
Only the AAZ lines will fit.  AHU lines are very different.  I would look for a set of used ones.  Shouldn't be a problem to get a good set for $50 shipped.
Reply #2January 15, 2014, 09:13:51 pm
Gizmoman
  • 1301
« Reply #2 on: January 15, 2014, 09:13:51 pm »
Thanks, that narrows it down. As far as getting used, I'd rather have new when it comes to parts that can leave you stranded. The e-bay set I linked to says they are new (and for as AAZ) but I have no idea what the quality is.
Reply #3January 15, 2014, 09:17:57 pm
wolf_walker
  • 1205
« Reply #3 on: January 15, 2014, 09:17:57 pm »
I've seen a bunch of aftermarket ones, presumably asian, for IDI's, no idea on quality.
Unless you stress one or do something unkind to it they don't wear out.  I'd buy
OE used too, there's a place in Cali that imports a bunch of 1.9's, I forget the name.
Mine are re-bent off a TD, single stage injectors though, think they are shorter.
Been on there for years, and were on the TD since 85.
Mentat Text Two
Reply #4January 16, 2014, 06:05:34 am
Gizmoman
  • 1301
« Reply #4 on: January 16, 2014, 06:05:34 am »
I emailed the outfit you mentioned - no response yet.
Too bad I have to learn everything the hard way. Used is OK I guess but there's no telling if they have been stressed as well. Doing a bunch of different searches yields lots of guys wanting them but none selling them.
I was going to move on the ebay set and the listing says he has 9 in stock but he's not selling them right now. . .?
I might remove mine and tig-weld the crack. Sounds silly but I don't know what else to do. I have no doubts I could tig it - just worried about the heat/scale on the ID messing up the flow or plugging the injector.
« Last Edit: January 16, 2014, 06:11:10 am by Gizmoman »
Reply #5January 16, 2014, 06:17:46 am
« Reply #5 on: January 16, 2014, 06:17:46 am »
CRSMP5 tig welded his AHU #3 and it has worked fine. I know your reservations though and understand. Might be good to have them as a spare.
Reply #6January 16, 2014, 02:18:54 pm
« Reply #6 on: January 16, 2014, 02:18:54 pm »
Maybe anneal them?
Reply #7January 16, 2014, 04:41:13 pm
Re:
« Reply #7 on: January 16, 2014, 04:41:13 pm »
I bought a set for my 1.6 made by Cohline. They're a German company. Might try seeing if they make a set for the AAZ, things are much easier with a part number.
Reply #8January 16, 2014, 04:59:21 pm
Gizmoman
  • 1301
« Reply #8 on: January 16, 2014, 04:59:21 pm »
Tig welding is off the list. . .
I guess there's no harm in trying though - can't hurt it at this point ;D
Anyone have a part number? This is line #2
Reply #9January 16, 2014, 07:16:49 pm
Gizmoman
  • 1301
« Reply #9 on: January 16, 2014, 07:16:49 pm »
I just bought the set I first listed from the e-bay seller - the guy replied to my inquiry and discounted them a bit as well. Hopefully I'll have them by mid next week.
Learned a hard lesson about loosening them up after moving the IP. After hunting for a set (new or used) for many hours and handing over a good chunk of earnings, these bits will be handled with serious respect in the future.
Reply #10January 16, 2014, 07:24:23 pm
Spokerider
  • 195
« Reply #10 on: January 16, 2014, 07:24:23 pm »
Good grief those are pricey pieces of metal........ ::)
So the idea is to loose off all 8 nuts before adjusting [ rotating ] the inj pump timing?
Trying not to spend any more $$ than required at this point of my aaz assembly.
Reply #11January 16, 2014, 09:14:15 pm
Gizmoman
  • 1301
« Reply #11 on: January 16, 2014, 09:14:15 pm »
Yup, that's what smart people do. ;)
If your patient, you might find them used somewhere for a lot less. Best thing to do is treat the ones you have with a lot of respect.
They don't care to be twisted, then vibrated while under extreme pressure much.
Reply #12January 17, 2014, 08:14:56 am
Blue Haze
  • 49
    82 caddy w/AAZ 1.9 motor 5spd w/ A/C
« Reply #12 on: January 17, 2014, 08:14:56 am »
You might try Quality German Auto Parts in Ontario, Ca  phone 909-391-6979.  He imports motors from Germany I think this is the person that Wolf Walker is referring to.  I bought my AAZ from him.
Reply #13January 17, 2014, 09:17:09 am
Mark(The Miser)UK
  • 1557
« Reply #13 on: January 17, 2014, 09:17:09 am »
Line #2 for AAZ is 028 130 302 C. Not sure if 1.9D/Eco fits which is 028 130 302B
I could be wrong , but that break being up at the #2 injector is a result of multiple tightening/undoing with the spanner and twisting the line. Best to tighten with the clamps off, if you are having slight fuel leak issues so that you can see if you are adding twist to the pipes with the final tightening...
 I don't think that moving pump from 1.05 to 0.95, without slackening of lines would do this, unless they were initially clamped somewhere in the 2.0 direction. Not really likely though...
When experimenting, dynamically, I always slacken all 8 nuts after each move. 0.1mm or 5 thou is well within limits.
Here is a great idea of mine given to you, and others freely...
 On your new set of lines, or even a known good old set:-
Take a permanent marker pen, and mark a line longitudinally from the nut of each fuel line back about 2" or so.
Do it at some convenient and referenceable position, for example on injector ends  facing the timing belt, and continue around the bend to the topmost part of each line. Do the same thing down at the pump end. you will now be able to see what is twisting, and why.
Mark-The-Miser-UK
Reply #14January 17, 2014, 09:38:01 am
wolf_walker
  • 1205
« Reply #14 on: January 17, 2014, 09:38:01 am »
I would admit to polishing both sides of the flare on each end and lubing them to encourage the nut turning and not twisting the pipe with it.
I've been accused of being fussy about some thing.
Mentat Text Two
