Author Topic: 300 tdi pump rover pump  (Read 6485 times)
January 15, 2014, 08:12:57 am
rodpaslow
  • 670
« on: January 15, 2014, 08:12:57 am »
I wasn't sure to add this here or in TDI -but I have a pump that will be going onto a 1Z/AHU tdi and I wanted to change the aneroid seal and the shaft seal.  When I pulled the aneroid off, I wasn't too careful and there is a lever on the front of the pump (if it were installed on engine) that is connected to the throttle with a couple small, light springs and small rod.
Inside the pump, does this go behind the control lever inside the pump?  I'm assuming it does so when you start moving the throttle the little springs move the control lever forward before the governor springs & lever take over?
The lever on the outside of the pump kind of looks like a late model 1.6TD idle lever (back of the 1.6 td pump) only this is on the front of the rover pump.
thanks for any help.
Reply #1January 15, 2014, 10:30:41 am
rodpaslow
  • 670
Re: 300 tdi pump rover pump
« Reply #1 on: January 15, 2014, 10:30:41 am »
[/url][/img]
Reply #2January 15, 2014, 10:31:01 am
rodpaslow
  • 670
« Reply #2 on: January 15, 2014, 10:31:01 am »
Reply #3January 15, 2014, 10:33:19 am
rodpaslow
  • 670
« Reply #3 on: January 15, 2014, 10:33:19 am »
Little black lever on bottom of above picture-I just want to confirm this goes behind the control lever inside the pump.  The governor lever isn't the same as this picture, but the bottom lever is.
thanks
Reply #4January 15, 2014, 10:36:06 am
8v-of-fury!
« Reply #4 on: January 15, 2014, 10:36:06 am »
I am thinking it stays like it is in the picture.. It is a fuel shutoff for atuo tranny cars in case of emergency.
It needs to help push the control collar towards the pumps snout, so that looks right.
Be more careful next time ;) This is not a demolition site! haha
Reply #5January 15, 2014, 12:52:35 pm
rodpaslow
  • 670
« Reply #5 on: January 15, 2014, 12:52:35 pm »
Thanks, I wasn't sure how it was when I took it apart, but this seems logical.
Reply #6January 18, 2014, 09:44:27 pm
« Reply #6 on: January 18, 2014, 09:44:27 pm »
you know dumb ***.. how many times you gotta be told it is NOT a fuel cut off...............
to the op.. talk to libby.... as im sure ill be banned once more........
log in.. read one post.. gotta correct stupid...........
Reply #7January 18, 2014, 10:23:12 pm
8v-of-fury!
« Reply #7 on: January 18, 2014, 10:23:12 pm »
I do not appreciate the barbaric name calling Christopher. Most certainly a fuel shut-off in the picture posted. If the op's pump looks like the one pictured. Spring loaded to stay up out of the way, swings down to push the internal throttle lever away from the governor opening the spill ports in the plunger for ANY rpm, resulting in engine shut-down.
ps. Who are you going to be banned by? Remember my moderator account was childishly deleted without even a single confrontation.
Reply #8January 18, 2014, 11:34:16 pm
« Reply #8 on: January 18, 2014, 11:34:16 pm »
The cover pictured doesn't look like my LR pump.  My LR pump had a compression governor spring capsule instead of the extension spring as pictured.  That looks more like the 4BTA style.
Anyway... often that lever on the side of the pump is a mechanical shutoff but it isn't on the LR pump, tho.  I have not found that it affects fueling at any time the engine is running.  Best guess I've heard was suggested by Vanbcguy...  maybe it reduces the puff of smoke at startup by limiting the control lever movement when the engine is off.
Reply #9January 18, 2014, 11:37:17 pm
8v-of-fury!
« Reply #9 on: January 18, 2014, 11:37:17 pm »
Do they look like the one pictured? With the lid off does the internal lever have noticeable movement that could swing far enough to be a shut-off?
If the lever does not affect fueling while running (meaning it is not touching the internal throttle lever) how would it touch it to  limit start-up fueling?? Just curious.
Reply #10January 18, 2014, 11:48:54 pm
« Reply #10 on: January 18, 2014, 11:48:54 pm »
On the rover pump that extra lever does not have enough swing to be a shutoff.  In fact with my engine running I've moved that to the off position and it doesn't even decrease idle...
The Rover pump has an interesting link between that lower lever and the accelerator lever.  Any time the accelerator lever is moved off idle it pulls that lever away from the position where it would limit fuel.  Because of this, any time you are above idle, the lever does not have any affect on fueling.  Without that lever, when the engine is shut off, the flyweights relax and allow the control collar to move to a greater-than-idle fueling position until the engine starts running and the flyweights push the control collar back away from higher fueling and maintain idle.  With that lever in place it could limit how far the control collar could move when the engine is off and the flyweights are pushing it back from higher fueling.  As I said, that's really the most reasonable explanation I've heard for that lever on the rover pumps.
Reply #11January 18, 2014, 11:50:42 pm
8v-of-fury!
« Reply #11 on: January 18, 2014, 11:50:42 pm »
Interesting. Yes, starting is full fuel enrichment. I guess we need a video of a Land Rover starting to see if it limits the start puff of smoke.. ?l lol
Reply #12January 19, 2014, 05:53:34 am
« Reply #12 on: January 19, 2014, 05:53:34 am »
then you should stick to things you can give correct info on....
1st post ive looked at in whiole and i have to fix your mis information????????? really!!!!!!
subject... rover 300 pump...
he states lever hooked up to throttle lever with springs and stuff...
those things = crsmp5... *** he ***en asked me what the *** it is 3 years ago.. we decided then if hooked to throttle lever canot be fuel shut off... but no you spout *** of stupid... yes your the reaon i no longer read posts here.. sick of reading repeate of stupidy you type...
next time you should say no fn clue.. ask libby...
« Last Edit: January 19, 2014, 05:55:58 am by CRSMP5 »
Reply #13January 19, 2014, 06:12:08 am
« Reply #13 on: January 19, 2014, 06:12:08 am »
No banning, right now it is just a conversation. Keep the conversation milder please. The asterisks are blocking the words but it can be inferred to what is being said and that could be something bad, if you would please edit out the asterisk words, you can show what is incorrect or a lack of knowledge without using profanity, if that is what you were using. Please remember that children can log on and ask what it all is about. The only thing ban worthy is in very small print, but I will leave that up to Red Rotors.
I prefer to leave everything relevant up and keep the flow of the board going. Sometimes things have to be taken out. or locked. Please help me to keep from having to do such things.
« Last Edit: January 19, 2014, 06:25:18 am by theman53 »
Reply #14January 19, 2014, 08:47:08 am
« Reply #14 on: January 19, 2014, 08:47:08 am »
I do not believe that starting is 'full enrichment'.  It is above where the control collar would be at typical idle, but there is not enough range of motion in the idle spring to move the control collar to the 'full fuel' position.  If you remove the accelerator lever return springs and the accelerator shaft o-ring and then put it back together without the return spring and o-ring and then operate the accelerator lever by hand, you can feel when the control collar stops moving and the idle spring begins compressing and then where the main spring comes into effect.  With my '79 rabbit, it takes a noticeably less cranking to start if I hold the accelerator depressed a little.
