Author Topic: AAZ main bearing bolts  (Read 4944 times)
January 11, 2014, 08:53:05 pm
Spokerider
  • 195
« on: January 11, 2014, 08:53:05 pm »
I'm doing an aaz crank nose repair [ AHU sprocket ] on a newly rebuilt engine with zero run time. This means I will be re and re the crankshaft. Can I reuse the main bearing bolts? Or are they a one time use stretch bolt?
This is not a high-pro rebuild, just keeping it in stock form.
I do have and will be using new connecting rod stretch bolts however.
Thanks.
Reply #1January 11, 2014, 09:09:52 pm
Re: AAZ main bearing bolts
« Reply #1 on: January 11, 2014, 09:09:52 pm »
They should be the 80mm long fully threaded IIRC and yes they are one time use.
Reply #2January 12, 2014, 08:25:05 am
Spokerider
  • 195
« Reply #2 on: January 12, 2014, 08:25:05 am »
Thank you.
I'll order them.
Reply #3January 12, 2014, 08:37:25 am
« Reply #3 on: January 12, 2014, 08:37:25 am »
There are two different sizes of AAZ main bearing cap bolts.
Reply #4January 12, 2014, 10:08:50 am
« Reply #4 on: January 12, 2014, 10:08:50 am »
For some reason I thought I was replying to the AHU thread...yes there were partially threaded 65mm long and the 80mm long full thread. IIRC the 65 are reusable, but the 80mm long are not.
Reply #5January 12, 2014, 10:15:05 am
« Reply #5 on: January 12, 2014, 10:15:05 am »
...and in either case I'd go with studs...
Reply #6January 12, 2014, 08:24:15 pm
Spokerider
  • 195
« Reply #6 on: January 12, 2014, 08:24:15 pm »
even for a" stock" engine......any appreciable benefit over oem vw bolts?
Reply #7January 13, 2014, 05:36:33 am
« Reply #7 on: January 13, 2014, 05:36:33 am »
Yes.
You can reuse them for sure, but the main benefit is that it will hold onto your main caps better. 2 or 3 guys here have cracked their main cap during normal operation.
Reply #8January 13, 2014, 08:46:46 am
Spokerider
  • 195
Reply #9January 13, 2014, 05:22:08 pm
« Reply #9 on: January 13, 2014, 05:22:08 pm »
I don't know. IIRC the bolts are M10-1.5x 65mm or 80mm so the studs would be the same only much longer like 100mm
Reply #10January 14, 2014, 08:08:52 am
Mark(The Miser)UK
  • 1557
« Reply #10 on: January 14, 2014, 08:08:52 am »
Why are studs better than bolts? :-\
Mark-The-Miser-UK
Reply #11January 14, 2014, 03:52:01 pm
