Author Topic: MKI radiator swap into MKII Jetta?  (Read 2466 times)
January 10, 2014, 04:20:59 pm
jaed_43725
« on: January 10, 2014, 04:20:59 pm »
So I am pretty sick and tired of the stupid coolant expansion tank (non-ball style) on my 85'. I can get a MKI radiator that came out of a 78 Scirocco for $30. Or I can get one of those inline fill caps like this: http://www.summitracing.com/parts/mor-63730/overview/
So will the MKI radiator fit right in, or is the inline filler better? I plan on using the expansion tank for the overflow. But I need to take this thing out of the pressurized equation.
Reply #1January 10, 2014, 07:01:47 pm
jaed_43725
Re: MKI radiator swap into MKII Jetta?
« Reply #1 on: January 10, 2014, 07:01:47 pm »
Also does anyone know the inside diameter of the upper radiator hose?
Reply #2January 11, 2014, 03:19:32 pm
sk8ordie
  • 20
« Reply #2 on: January 11, 2014, 03:19:32 pm »
yes an early MKI/ rocco rad will fit/ work in a MKII. And it will keep your 1.6 cool. I've run non overflow rad's in my last few builds. Inline fillers are junk - and you will have air issues if its not at the highest point of the system. This is difficult to achieve in line naturally.
Reply #3January 11, 2014, 09:03:50 pm
jaed_43725
« Reply #3 on: January 11, 2014, 09:03:50 pm »
Is there anything I have to do to make it fit in right? Or will it fit in just like the current one?
Reply #4January 11, 2014, 09:10:33 pm
« Reply #4 on: January 11, 2014, 09:10:33 pm »
There are a bunch of holes in the core support, you have to put it in the right ones for the radiator you use.
Reply #5January 12, 2014, 07:42:43 am
sk8ordie
  • 20
« Reply #5 on: January 12, 2014, 07:42:43 am »
yes - you'll need to reconfigure your rad hoses.
Reply #6January 12, 2014, 10:11:53 pm
8v-of-fury!
« Reply #6 on: January 12, 2014, 10:11:53 pm »
Why??
Reply #7January 12, 2014, 10:50:47 pm
Dakotakid
  • 1240
« Reply #7 on: January 12, 2014, 10:50:47 pm »
Exactly my question as well.
If it's a matter of the age-related cracking of the res., those are actually quick, easy, and inexpensive to replace. They also make determining anti-freeze level quick and easy as well.
I hate the ball-style res. They seem to be hard to read even with a very clean system.
I remember the old side-saddle res. radiators as short-lived leakers. I actually installed remote res. radiators in all my Mk. I's. Life was good.
« Last Edit: January 12, 2014, 11:00:33 pm by Dakotakid »
Reply #8January 13, 2014, 04:22:24 am
« Reply #8 on: January 13, 2014, 04:22:24 am »
my brother has one in his mk2 aba, i think there was 1 bracket on the upper radiator support that he had to cut away to make it fit but it worked fine and keeps his car cool.
