Author Topic: How to determine notches regarding head gasket type  (Read 38562 times)
Reply #60February 16, 2014, 09:24:03 am
92EcoDiesel Jetta
Re: How to determine notches regarding head gasket type
« Reply #60 on: February 16, 2014, 09:24:03 am »
I only asked you to prove what you said man..
You said no because we are not worth your time..
Why do you post here then??
Enough. You are putting words into his mouth, he never said anyone here was not worth his time. Last warning.
Can a moderator give warning to another moderator? Is there a moderator pecking order?
Reply #61February 16, 2014, 09:37:09 am
bbob203
  • 1789
« Reply #61 on: February 16, 2014, 09:37:09 am »
8v was demoded a few months ago. His entire account deleted hence his new account has a "!" at the end.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #62February 16, 2014, 10:20:16 am
92EcoDiesel Jetta
« Reply #62 on: February 16, 2014, 10:20:16 am »
Really!!! What happened?
Reply #63February 16, 2014, 10:29:18 am
92EcoDiesel Jetta
« Reply #63 on: February 16, 2014, 10:29:18 am »
Somehow I don't buy this quenching theory by just doing fluid dynamic analysis in my head. ;D To dissipate heat from the piston crown efficiently by quenching, it needs dwell time and contact to the head. There is no contact and the dwell time is what? milliseconds? Unless I see some proof, I am sticking to it.
Reply #64February 16, 2014, 02:26:46 pm
« Reply #64 on: February 16, 2014, 02:26:46 pm »
Remind the machinist  in you head the piston is stationary at TDC and BDC
Reply #65February 16, 2014, 03:47:33 pm
« Reply #65 on: February 16, 2014, 03:47:33 pm »
1200rpm = 20r/s
1sec / 20 = .05s/rev
50ms / 360 = .138ms/degree crank
So, if you want to say dwell is ten degrees, then that's ~1.4ms.
Check that math... I've buggered it before.
Reply #66February 16, 2014, 05:02:25 pm
Mark(The Miser)UK
  • 1557
« Reply #66 on: February 16, 2014, 05:02:25 pm »
Does 4 stroke have to be factored in? Clearly getting near to my bed time as my brain is fuzzing.  ;D
Mark-The-Miser-UK
Reply #67February 16, 2014, 08:33:58 pm
92EcoDiesel Jetta
« Reply #67 on: February 16, 2014, 08:33:58 pm »
Stationary for what, a milli-second? not enough time to transfer much heat. I can put my fingers on hot coals for a milli-second without much heat transfer won't get burned.
Reply #68February 16, 2014, 09:09:05 pm
« Reply #68 on: February 16, 2014, 09:09:05 pm »
Isn't the goal to not transfer heat? Unless you are running the piston  up to touch the head and sending heat from the crown to the head that way ::)
We are protecting the  most delicate part of the piston  at the time heat is the highest.
Reply #69February 16, 2014, 09:11:19 pm
Gizmoman
  • 1301
« Reply #69 on: February 16, 2014, 09:11:19 pm »
Do it several gazillion times for a few hours. I'll bet you have some odd looking fingers ;D
Reply #70February 16, 2014, 11:37:33 pm
Toby
  • 728
« Reply #70 on: February 16, 2014, 11:37:33 pm »
This argument is kind if metaphysical. It is no more relevant than arguing about how many fairies can dance on the head of a pin.
Has anybody here actually put in a 3 notch when a one notch was called for????
Well I have. I did that once when I did not have the correct "notch" in stock. Fresh motor that I wanted to put some miles on. I ordered the 1 notch and drove the car for over a month with the 3 notch before I swapped out the correct gasket. I was expecting more power, less smoke, better starts, and better mileage. I can not attest to cold start performance because it was not cold here then, but I noticed NO DIFFERENCE. Nothing, Nada.
It did not feel faster, did not start better, did not smoke less, and the fuel mileage did not go up.
So I ask you how important is it really?
Reply #71February 17, 2014, 05:13:44 am
« Reply #71 on: February 17, 2014, 05:13:44 am »
I did it on my last build as to increase performance since I was running higher boost. I noticed that every time I started the engine it ran rougher and had white smoke out the tailpipe. It could be 95f out and still white smoke if you were watching.
Reply #72February 17, 2014, 05:27:01 am
bbob203
  • 1789
« Reply #72 on: February 17, 2014, 05:27:01 am »
I bet he won't believe you.
03 Jetta wagon TDi
Reply #73February 17, 2014, 06:41:56 am
92EcoDiesel Jetta
« Reply #73 on: February 17, 2014, 06:41:56 am »
I was questioning the statement from libbydiesel (copied below), the part that increasing space between piston crown and head at TDC by using a thicker head gasket will have negatively affect quench and cause the piston crowns to run hotter. I take it that Libby meant quench is needed for piston crown in a TD engine and having too thick a head gasket negatively affects quench, which is more important than the lowering of compression due to thicker head gasket.
       "The compression difference is not really of issue.  The other two factors are 'squish and quench'.  Squish establishes the correct turbulence, again probably not an issue on a pre-chamber diesel.  Of particular issue, tho, in a TD is quench where a significant amount of heat is transferred from the piston crown to the more cooled cylinder head.  Increasing the space between piston crown and head at TDC will have negatively affect quench and cause the piston crowns to run hotter."
Reply #74February 17, 2014, 07:07:22 am
« Reply #74 on: February 17, 2014, 07:07:22 am »
Lots of good info in this old thread... http://www.vwdiesel.net/forum/index.php?topic=8369.0
If you look at page 6 of this thread you will see that sauerkraut has done this experiment. Later he went with the same engine but a 1.9 head and the correct gasket and it ran well. The 1.9 has bigger prechambers and therefore lower CR, but the starting issue was solved. Granted it is one car, one guy, one engine, one experiment, but it sounds like a good one and that our theories are not far off.
