Author Topic: RPM hang on 1.6 n/a CR engine  (Read 6786 times)
Reply #15January 18, 2014, 03:02:56 pm
sgnimj96
  • 185
Re: RPM hang on 1.6 n/a CR engine
« Reply #15 on: January 18, 2014, 03:02:56 pm »
       I got the pump back on and the rpm's don't hang badly anymore  :).   The IP had mostly rust grit inside of it,  not much sludge at all.    The control collar seemed to move freely but the grit had really collected in the timing piston at the bottom;  that pump definitely needed to be disassembled and cleaned out.        Thanks for the advice!
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
