Author Topic: Ultimate winter mode? Problems and solutions..., also, in cab heater anyone?  (Read 17850 times)
Reply #30January 14, 2014, 06:45:01 pm
shorttimer
  • 121
What's winter? It was 80 today.
Reply #31January 15, 2014, 06:59:32 pm
Enslaved_Pickle
  • 45
I took the tensioner arm out today and inspected it and the bushing. They are both fine, no play and no grinded down arm. I re-greased the crap out of it and made sure the pulley spun freely. Threw it all back together and started the car,..... It still squeaks :( its slightly quieter but still there. Any other ideas?
Mk3 1.9L turbo diesel rat
Reply #32January 15, 2014, 07:14:25 pm
My tensioner looked fine and the pulley spun freely. I replaced it and the noise stopped immediately. If it got quieter after greasing I would still guess that is your issue, you probably just need new.
Reply #33April 01, 2014, 05:15:50 am
Enslaved_Pickle
  • 45
Soooo, the squeaking has gotten much worse, it appears that the crank pulley is wobbling more than it was when i bout the car.
I have removed the factory crank bolt and inspected the keyway and there was no signs of wear. I bought a new crank bolt, covered it in red locktite and torqued it correctly. I have also marked a line across the bolt and the sprocket so i would know if it started to loosen.
So now i've replaced
- crank pulley
- crank sprocket bolt
- tensioner and pulley
- 3 different serp belts
 the bolt has not moved at all, i'm ready to throw my rusty 1.6na in just to stop the squeaking :( Any ideas?
Reply #34April 01, 2014, 05:18:59 am
did you get a new tensioner, or did you only grease it and reinstall it?
Again, mine looked fine and felt fine, but when I put the new one on all the noise went away.
Reply #35April 03, 2014, 03:52:29 pm
Enslaved_Pickle
  • 45
Did you get your parts online? I called the dealer today and they can't get the bushings or the tensioner arm :(
Reply #36April 03, 2014, 03:57:39 pm
http://www.idparts.com/catalog/product_info.php?cPath=29_90&products_id=629
Yes, I did, but mine is MKIV. I don't know if the tensioners are the same, but I do know mine stopped immediately after replacing. I even talked about it to my mechanic friend and he thought it was so bad that the bearing or clutched pulley was going out of the alt and I should start saving for that. But when I replaced the arm and the entire deal the noise went away completely.
Reply #37April 04, 2014, 05:44:17 am
srgtlord
  • 797
Reply #38April 04, 2014, 06:21:23 am
That doesn't have the new arm and all the bushings that I could see. That is why I didn't post that for him. I think the problem is in the pivot of the arm when under all that tension.
Reply #39April 04, 2014, 08:02:54 am
I see both an arm and the bushings on that link, even the seals for the arm?
Reply #40April 04, 2014, 02:03:17 pm
My bad, I missed that arm before ...2x
Reply #41April 29, 2014, 05:54:21 pm
Enslaved_Pickle
  • 45
Alright, i'm officially done, if the next thing i do doesn't get the squeak to stop i'm parting out the car.
I changed the tensioner, the tensioner arm and both bushings yesterday with new oem vw parts and it still squeaks!!!! :(
Anyone want an aaz?
Reply #42April 29, 2014, 06:17:04 pm
Re:
« Reply #42 on: April 29, 2014, 06:17:04 pm »
Have you tried using a mechanics stethoscope to narrow down the source of the squeak?
Reply #43April 29, 2014, 09:28:14 pm
srgtlord
  • 797
maybe its the alternator? Or the harmonic balancer?
Reply #44April 29, 2014, 09:40:56 pm
Enslaved_Pickle
  • 45
Already swapped alternators and harmonic balancer is new
